AMIKO Amiko Mini HD SE . Youtube does not work
Vallenato
222
10
America
I have noted since some weeks ago that youtube on Amiko Mini HD SE does not working. It showing a message that something wrong with the servers and needs to be update Call support or someting like that..
Anybody else
Thanks in advance
Anybody else
Thanks in advance
I haven't used it in a while but just checked. It says Youtube is upgrading to a new version which is no longer supported by the device or app and directs you to visit www.youtube.com/devicesupport which tells you that certain devices and apps will no longer be supported after April 2015. Does anyone know if Amiko will be providing a firmware update to address this?
Exactly thanks for the information..
Seems generally this issue I saw on another site that some FTA & IPTV receivers has the same message..
They are aware of the problem. I have not heard any more yet.
I see they have put out a new firmware to fix YouTube, for a couple of their older boxes this week, so hopefully they will get to this one very soon.
And what about the Amiko micro hd se?
Is there any firmware update for it yet?
Because youtube is not working on it either, your help will be much appreciated, thanks.
There is, but you will need to get it from the Amiko Official site, as I have no way to test here, to verify it. I do not own one of those receivers.
BTW, Welcome to SatelliteGuys!!
Thank you ,
But can you tell me the link cause I can't find any new firmware of june 2015 for amiko micro hd se on amiko's website?
Be aware that the video resolution will need to be set to 60hz after the firmware update as per this thread:
http://www.satelliteguys.us/xen/threads/amiko-mini-hd-se-firmware-2-2-06-youtube-fix.350902/
Hint: Also save as the default if you don't want to be bothered with resetting the video resolution if you ever need to perform a factory reset.
The mini HD SE firmware patch is available either online using the STB update menu or download the current patch and install via USB:
http://www.namini.tk/index_files/Page318.htm
The file will be unzipped as NAMINISE-2206PATCH.abs
