AZBoxEdit Run-time error 380. Invalid property name.
vpaniyan
55
US
Guys,
To see data values in the "antenna_list.dat" and "DVBS.dat" files, I use AZBoxEdit (Tab - Organize Sat & TP) versions : 0.9.7b; 0.9.2880; 0.9.2880a.
All 3 version have the same problem, I can check 8 - 9 records from the bottom of the satellite list, but for every satellite above that the program crashes with the following message: Run-time error 380. Invalid property name.
I deleted couple of satellites above the records 8 - 9, but the problem still persists.
Did anyone came across this problem?
Vpaniyan,
I have not observed this error before with AZBoxEdit.
What do you mean by "to see data values"? Do you mean that you are clicking on one of the satellites in order to view the transponder list and setup information?
Not sure what to tell you. Try Googling for that specific error code and see if you can find something, some answers that might help explain it.
RADAR
I fixed the problem - "Data Reset", download the files and was able to click on the satellites.
