Hi,
I have way too much difficulties to find anything with a Signal Strength near 90% and a High signal Strength for the Quality.
Right now I just have a high signal strength but the quality do not go higher than 10%.
I have switched my LNB for the following one, please see below
I have a Fortec Star 33 inch dish, a SG2100 Motor, a Digiwave Diamond Receiver (Like a CoolSat 4000 Pro:
My idea is the following, use this LNB to find Nimiq 1 (91 W), I have already a dish on Nimiq 1 that is perfect, so I will try to use this dish and the satellite as a reference for my setup. Mainly the idea came out when I read that those satellite have a strong signal.
Can you guide me on how to set the LNB and how to set up a manual scan so I can point my dish correctly.
I see the following info in lyngsat for Nimiq 1:
12224 R
tp 1 Satlogo Bell ExpressVu AddressPackages DVB
Nagravision 20000-5/6 256-1
Canada B Gémus
050330
Bell ExpressVu Info Channel Address Free TV 198 5410 5411
New Rock Edge 102 (CFNY) (Toronto) Address Free Radio 955 E
CFMX-FM - Classical 96 FM (Toronto) AddressNet Radio Free Radio 961 E
RFI - Radio France Internationale AddressNet Radio Free Radio 971 F
Radio Desjardins
Free Radio 981 F
Radio Metro Address Free Radio 982
Radio Herz AddressNet Radio Free Radio 986 G
DG52N DSS DUAL
LNBF
Specification
Frequency Input Freq. Range 12.2 ~ 12.7 MHz
Output Freq. Range 950 ~ 1450 MHz
Conversion Gain 50 min. 62 max. over
temperature
Gain Variation +/- 0.5dB max. across
any 24MHz segment
5dB (Max.) across the
500MHz bandwidth
Noise Figure 1.1dB ( Max.) entire
operating temperature range
Local Oscillator
Frequency Stability 11.25GHz +/- 2MHz @ 22
degrees C after 15 minutes warm up period
11.25GHz +/- 4MHz @ -35
degrees C ~ +52 degrees
Output VSW 2:1 ( at 75 ? system)
Image Rejection 40dB (Min.)
Output 1 dB Gain
Compression Point 0dB ( Min. )
Polarization Isolation 20dB ( Min.) 25dB ( Typ
Power Requirements Voltage Level 10.5 to 14 Vdc ( RHP )
15.5 to 21 Vdc ( LMP )
Current 120mA ( Max. ) 100mA (
Typ. )
thanks
Regis
12224 R
Canada B Gémus
050330
Radio Desjardins
Free Radio 981 F
DG52N DSS DUAL
LNBF
Specification
temperature
any 24MHz segment
500MHz bandwidth
Local Oscillator
Output 1 dB Gain
Typ. )
thanks
Regis
