Ok I’ve gotten the dish setup but I can’t figure out how to get it to pass the check switch test
It won't have any effect on you current issue, but for aiming urposes, I'd suggest covering the far left and far right "eyes" with foil as you face the LNB. The far left one is for the no longer used 77 satellite but is close enough to the 72.7 "eye" that it's easy to hit the wrong one. Once the 72.7 satellite (center eye) is dialed in, removing the foil on the far right 61.5 satellite eye should find it pretty much dead on. For even better reception and easier aiming, I've switched all my eastern arc 1000.4 LNB's to 1000.2 dual "eye" LNB's. They fit the 1000.4 arm with just a minor mod to the plastic arm adapter.Also if it matters the lnb is a eastern arc 1000.4 lnb
You have to point it before you run the check switchSo dose anyone know how to get it to pass check switch or do I have something hooked up wrong?
