Controlling 2 H-H motors with one receiver
Discussion in 'Free To Air (FTA) Discussion' started by vicdiaz, Oct 22, 2012.
  1. vicdiaz
    vicdiaz Thread Starter Member
    Jun 3, 2011
    26
    Trujillo Alto, PR
    Hi,
    Is this possible??? Motors are SG2100 and DG380. Receiver is a Openbox S10.
  2. Magic Static
    Magic Static SatelliteGuys Family
    Oct 12, 2010
    3,219
    251
    W Montana
    It can be done with other receivers, but I don't know the OpenBox models. I use an 8x1 DiSEqC 1.1 uncommitted switch to combine /seperate the motors. You have to be sure the switch will pass enough power for the motors. A lot of switches post that power passing spec.
  3. SatelliteAV
    SatelliteAV SatelliteGuys Family
    Pub Member / Supporter Corporate Pub Member / Supporter
    Sep 3, 2004
    6,100
    10
    Roseville, CA
    Yes it is possible, but will exceed the maximum current rating of the receiver. An external power inserter would be necessary to power one of the motors.
  4. markbone100
    markbone100 Active SatelliteGuys Member
    Jan 15, 2011
    305
    IL
    I have an 8x1 diseqc switch that has an a motor on the other end operated by an openbox s10. It works perfect for me, no voltage issues at all.
    id like to get a vbox and operate the bud with it too but havent broke down to buy one
  5. Anole
    Anole SatelliteGuys Guru
    Sep 22, 2005
    11,819
    L.A., Calif.
    One solution
    We've had discussions here on the forum on modifying both those motors for external power.
    This thread might give some helpful info:
    http://www.satelliteguys.us/threads...-380-Separate-Drive-Power?highlight=Motor+380
    With both motors on 18-20 volts, they would be zippier.
    The receiver power supply would not be overloaded.
    Any old switch would work, because it only had to carry power for the LNBF.
    I'm curious why you'd want two motors on a single receiver?
  6. primestar31
    primestar31 SatelliteGuys Family
    Mar 15, 2005
    3,925
    347
    Michigan - Under the bridge
  7. Mikey11
    Mikey11 Active SatelliteGuys Member
    Nov 9, 2009
    803
    4
    canada
    i have done it with an ecoda 22khz switch before
  8. vicdiaz
    Jun 3, 2011
    26
    Trujillo Alto, PR
    Thanks all for your ideas!!!
    Planning on using my 1.2m offset as a mini-bud and the .90m for Ku, both motorized.
VigLink badge
Sucuri
