I need to purchase some more programming and need to know if the Discovery suite channels on W5 end on 1 June, or 30 June? I'm very satisfied with my Skyvision basic pack, but absolutely have to have the Discovery suite channels. Thnx
Have you called and asked them about it, they might have the correct answer for you. Your other choice is just order the Discovery pak on a monthly base until the correct answer comes out.
Screw Charle get Direct if you must have pizza or get Cable. In fact Charlie came down from my neighbors house the other day and he got Direct. Charlie is screwing his subs left & right. I don't forsee H2H not working something out. The problem is where to put the channels X4 or turn on the masters. Last I heard X4 is the cheaper route.
Sorry, I had the impression you worked for SRL and might know.
Direct is way too high!!!! and I'm on a fixed income [zero - job went to Mexico], and 'rely on the kindness of strangers'.
Cable is not available way out here. Matter of fact, we are so deep in the holler, they have to pump sunshine in here.
I can get IPTV through local phone co-op, but they charge extra for Discoverys.
It w/b $53.95 + $6.95 [discovery] + $16.95 [HD] = $77.85 + tax [9.75%] = $85.44......insane!!! BLTV goto packages and pricing, choose a zip code, and you can then see info. And IPTV HD is about the same as Masters DCII SD. Father - in - Law has the phone line TV from BLTV. They use copper wires, if they ran fibre to the home, every ch. could be in 1080p [if ch. was 1080p]
And I can get most of that with [ugh] pizzasat HD [free for life!!!...wonder how that will end?] for $29.95 for the 1st yr....and who knows or cares...the way the country is going, the $$$ may be worthless and the 2nd yr may be moot.
I'm totally satisfied with the Skyvision pack for TV, just have to have Discovery suite of channels.
Perhaps, like when the conversion to HITS took place, its time to (stress here the next word) politely contact Discovery with notes of support as we did earlier? This site has a history of being viewed in a positive way by others, and "thank you" for carrying/continuing to carry couldn't hurt! Specifically mentioning the H2H/SRL method of purchasing for us C-band people. Not sure if its a hard and fast contractual issue, or if they could extend again. They seemed to want us viewing when the issue first surfaced!
Thoughts?
