Elevation and Latitude?
Thanks for the help, I have been reading many topics. I have the T5 my southern sat at 90% and 75%. When going to other sats the quality jumps from 80-90% but on some no signal quality(weird). So I blind scan and do receive some of the tp's. Over time it will get better and more of the available stations will be located.
The signal quality will always fluctuate slightly, but double check all connections are tight (hand tight then just the weight of a wrench)
Also make sure everything on the dish and motor is tight, if the dish is high up it may be moving slightly in the wind. Sometimes this is worse than Rain Fade!
Feeds come and go all the time, every time you blind scan you will find a few more.
If you are using USALS some satellites will need to be set up using DiSEqC 1.2, enter a LIVE TP. and motor the dish until you see signal quality, then number and store the position.
New C/Ku LNBF to be released
SQ on the University Channel
