Good article about OTA
ericdoc
16
High-Maintenance TV
Published June 24. 2004 7:30AM
New York Times
THERE are people for whom getting something to work right is half the fun.
For them, there's a new challenge: viewing the digital versions of free
broadcast TV.
At some point, cable and satellite services will offer many local digital
stations. But until then, watching "The West Wing," the N.B.A. finals or
"C.S.I." in HDTV, the digital format that offers gloriously sharp
wide-screen images, usually involves getting the signals the old-fashioned
way: by means of an antenna and a decoder box. And that can often make grown
men cry.
While many users apparently have no problem receiving HDTV or other digital
broadcasts, others have flooded online discussion groups like AVS Forum
(avsforum .com) with tales of woe.
These users report that decoder boxes may pull in some broadcast stations
but not others, depending on the time of day, distance from the transmitter,
proximity to other buildings and weather conditions. Boxes from every
manufacturer are reported to freeze up and to require rebooting, usually by
hitting a reset button or by unplugging the box and then plugging it back
in.
Rebooting is not something you expect with a service meant to be as stable
as plain old TV.
Neither is constant fiddling with an antenna, something many consumers
thought had ended years ago when they threw out their last rabbit-eared TV
and hooked into cable or satellite service. But for a digital TV antenna to
work properly, its aim must often be as precise as a sharpshooter's.
"Installing an antenna is easy to do as long as you have a signal meter,"
said John C. Thomas, an HDTV aficionado in Canton, Ga. But signal problems
occur if he rotates the antenna even slightly.
When he first installed the antenna in his attic, Mr. Thomas used trial and
error, moving it around until he found a sweet spot where reception was
best. And it is very sweet indeed. "If I move it a few feet away, then I
introduce signal problems that the HDTV decoder box can't deal with," he
said.
Perhaps fortunately, a majority of digital TV owners are not even trying to
watch digital broadcasts. Since the transition to digital broadcasting began
in 1998, 8.3 million households have acquired digital TV's, according to
Adams Media Research. But only 1.7 million of those have the built-in
hardware or set-top box necessary to receive and decode HDTV broadcast
signals. The owners of the other 6.6 million sets are using them to watch
standard-definition TV and DVD's.
Under a Federal Communications Commission ruling, all TV's will eventually
come with built-in digital broadcast tuners. And later this year,
manufacturers will introduce cable-ready digital sets that can receive
channels like ESPN-HD and HBO HDTV without a decoder box. According to the
Leichtman Research Group, by the end of this year, 3.5 million viewers will
be watching some broadcast and cable HDTV channels by cable or satellite.
But today, those who want to watch digital broadcasts free still usually
need to use an antenna and a set-top box. And that is where the fun starts.
Manufacturers of decoding equipment say that the problem is not with their
hardware. "We've had no decoder boxes returned due to reception problems,"
said John Taylor, vice president for public affairs at LG Electronics USA,
Zenith's parent company and a major decoder manufacturer, along with
Samsung, Thomson (RCA's parent), Toshiba and others.
Mark Richer, president of the Advanced Television Systems Committee, the
industry group overseeing the transition to digital television, acknowledged
that "like a cellphone or satellite TV, there will always be places where a
digital broadcast set-top box won't work well."
Rick Roome, a software engineer in Simi Valley, Calif., knows this
firsthand. With his equipment, he can receive the digital feed of almost
every Los Angeles station. But even though he is using a 17-foot antenna on
his roof and lives just 35 miles from the Mount Wilson transmitter, "some
days, the ABC station breaks up, freezes and then disappears," Mr. Roome
said. "It happens especially around sundown."
Such reception problems can arise from several factors.
Digital set-top boxes are as complex as computers; when broadcasters send
digital signals that do not exactly adhere to the official transmission
standards, the box may be incapable of handling them.
To cut power bills when digital viewers are few, most broadcast stations
that transmit a digital signal are using less than full power to do so. This
not only reduces the range that the signal can travel but also provides a
weaker signal even when a customer lives well within the coverage area.
Living closer to a broadcast tower does not reduce the likelihood of
reception problems. Urban residents can suffer from the effects of multipath
transmissions, signals that bounce off buildings and hills and arrive at the
TV from several directions.
The earliest digital set-top decoder boxes dealt so poorly with multipath
transmissions that the Sinclair Broadcast Group, owner of 62 TV stations in
39 markets, petitioned the F.C.C. to allow for the simultaneous adoption of
the European digital broadcast standard, arguing that it was much easier to
receive.
Both Thomson and LG say they will incorporate new technology into their
next-generation digital TV decoders that should eliminate multipath
reception problems. Most consumers will then be able to use just a small
indoor antenna to watch digital TV.
"LG's new technology is a giant leap toward addressing the multipath
reception problems," said Nat Ostroff, Sinclair vice president for new
technology. Now that consumers will easily be able to receive digital
broadcasts, "the incentive is there for us to go to full power."
Still, those advances will not solve all set-top-box problems. Tony Boyd, a
retail store planner in Dallas, has no problem receiving digital broadcast
channels with his decoder box and an antenna. But when he is watching some
HDTV channels on DirecTV, the audio or video drops out from time to time,
and the box occasionally freezes. Mr. Boyd has gone through two units, but
the symptoms persist. "DirecTV cannot solve the problem," he said.
In addition to technological improvements, Mr. Richer's group, the Advanced
Television Systems Committee, is working on a set of "recommended
practices," guidelines for minimum performance standards for digital
receivers. And antennas are not being neglected, either: within months,
versions that electronically tune themselves without being moved to receive
the strongest signal will appear on the market.
Even when HDTV programming on cable and satellite services becomes
ubiquitous, reliable reception of broadcast digital channels using an
antenna will remain important, broadcasters say. There will always be people
who do not subscribe to satellite or cable, or do not have it hooked up to a
second or third set. In addition, some broadcasters have floated the idea of
offering a mini-package of cable channels, delivered over the air as a
digital broadcast signal.
That plan can only work if reliable reception is a given. "Digital converter
boxes are getting better," said Ken Holsgrove, an HDTV consultant and an AVS
Forum moderator. But for customers who expect current over-the-air digital
TV to work like regular TV, he had some advice: "I'd steer clear of it. The
technology will not support their expectations."
Boxes from every
in.
Great article, but they fail to indicate that it is the DBS boxes which incorporate OTA reception that are the ones that need frequent rebooting. They are the ones in the most use, but the OTA only set top boxes don't need rebooting as they don't have major software like program guides, channel mapping, etc... What ever the station sends you get.
Has anyone ever had to reboot a Zenith OTA STB? Is there even a way to reboot one? All it does is scan and save what channels you receive, no program guide unless you press "info" and the station sends text about the program, and no channel mapping other than PID sent by the station. Other than channel up-down, channel number entry, Closed Captioning, and language simulcasts the unit does nothing else.
In the case of digital OTA broadcasts the simpler the STB the better.
