Systems in this CE
H21-100 • H21-200
H23-600
Window of opportunity to download:
Friday, February 13, 2009 11:00PM - 2:30AM ET
Saturday, February 14, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
Known Problems
Notes
H21-100 • H21-200
H23-600
- Items from CE:17:01 High Risk
- Items from CE:17:02 High Risk
- Items from CE:17:03 High Risk
- Items from CE:17:04
- Items from CE:17:05 High Risk for H21-100 Moderate Risk for H21-200
- Items from CE:17:06 High Risk for H21-100 Low Risk for H21-200
- Items from CE:17:07 Moderate Risk for H21-200
- Items from CE:17:08 Risk: Moderate (H21-100) Low (H21-200) High (H23-600)
- Items from CE:17:09 Risk: Moderate (H21-100) Low (H21-200) High (H23-600)
- Items from CE:17:10
- 01 - Network
- 01 - Media Share
- 01 - Music Screen Saver
- 01 - Game Search
- 01 - 1080p/24
- 01 - OTA via the AM21
- 01 - Autotune
- 01 - Multi-Room Viewing
- View Playlist from a networked HR2x or R22
- Playback/Trick Play functions from any networked HR2x or R22
- Press {LIST} to see HR2x or R22 servers
- one playback per server at a time
- 02 - Parental Controls when scheduling autotune
- 02 - MRV: bookmarks and resume playback from previous location
- 04 - Friendly name in network setup
- 04 - QuickTune
- 05 - Built-in Self Test
- 02 - Support for more 1080p Sony TV models
- 02 - Faster Guide scrolling
- 02 - ATSC signal meter performance
- 02 - Fixed a screen saver issue
- 02 - ATSC setup screen now works on first boot
- 02 - Fixed reappearance of deleted autotunes
- 02 - UI updates ("tuner 2" and "tuner 3" references)
- 02 - Fixed Gray Screen or a PPV OSD appearing overnight
- 02 - Improved "Try Again" when trying to connect to the Internet.
- 03 - AV1/AV2 remote code refinements
- 03 - Improvements to DHCP network setup
- 04 - Issues with rebooting while in standby
- 04 - WGA600N Support
- 04 - Static IP Setup
- 05 - Stability
- 05 - Missing “Just a few seconds” OSD
- 05 - MRV playback and trickplay problems
- 05 - User Interface polishing
- 06 - Network services, Network setup, Network status
- 06 - One touch autotune via Enter key
- 06 - H21-100, SWM compatibility--will not affect other boxes
- 06 - H21-100, remote control support
- 06 - Removed “Reformatting Hard Drive" screen after Reset Everything
- 06 - Changing Display Language
- 07 - One touch autotune via Enter key
- 07 - WGA600N setup with WPA encryption
- 07 - Receiver not resetting
- 07 - Closed Captioning Loss
- 08 - Autotune on ATSC channels
- 08 - WGA600N setup with WPA encryption
- 08 - UI Improvements
- 08 - Missing spending limit unlock OSD
- 08 - SWM issue, Signal Strength H21-100
- 08 - System test H21-100
- 09 - Network Setup
- 09 - Autotune on ATSC channels
- 09 - Keyword search
- 09 - Screen flash coming out of Standby
- 10 - Improved Front Panel display on boot up
- 10 - IR Remote H21-100
- 10 - Remote setting when reset defaults
Known Problems
- [strike]02/06 - Support for WGA600N[/strike]
- [strike]02 - DHCP network setup[/strike]
- [strike]04 - Network Services may not work[/strike]
- [strike]05 - Diagnostic reports do not work[/strike]
- [strike]05 - H21-100, intermittent “Searching for Satellite” OSD[/strike]
- [strike]06 - H21-100, signal strength screen[/strike]
- [strike]06 - H21-100, may lose satellite signal after several hours requiring reset[/strike]
- [STRIKE]07 - WGA600N setup with WEP encryption[/STRIKE]
- [STRIKE]08 - WGA600N setup with WEP encryption[/STRIKE]
- 09 - WGA600N setup with WEP encryption
Notes
- Reverting back to National Release will go back to default settings
- 01 - To enable MRV:
- Network must be enabled
- Enable IAMANEDGECUTTER keyword
- Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
- Network must be enabled on HR2x and R22 DVRs
- [STRIKE]Please test the box as a standard H21 before enabling the Multi-Room View Client feature and report issues[/STRIKE]
- [STRIKE]Then please test MRV (veggies before dessert)[/STRIKE]
- [STRIKE]When reporting MRV issues, please include the logs from both server and the client[/STRIKE]
- 01 - Please report all occurrences of “Unable to Access to Media” OSD with logs
- When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
- Please report non-MRV issues only
