Help me identify this dish
dishdude
SatelliteGuys God
25,457
46,422
Phoenix, AZ
This is an eastern arc dish, I believe a 1000.2. Can anyone confirm? Also, can I replace the LNB and convert it to a western arc?
HipKat
17,401
32,938
Pekin, IL
1000.2 Eastern Arc which is missing 2 bolts from the skew plate. Yes, you can convert it but you need a western Arc LNB
Reactions: dishdude
dishdude
SatelliteGuys God
25,457
46,422
Phoenix, AZ
So if I have this correct, the 1000.2 EA and WA dishes are identical other then the LNB?
Is it true that the 1000.4 EA and WA dishes are different and cannot be converted between EA and WA?
is 1000.2 the one being used on new installs?
JSheridan
8,899
10,028
USA
1000.2 EA and WA dishes are the same.
1000.4 dishes can be used on either arc depending on the LNB.
Yes, 1000.2 dishes are used on new installs.
Reactions: dishdude
HipKat
17,401
32,938
Pekin, IL
Yeah, it was the same back home, skew was 81, but in this pic, you can see the bolt holes
HipKat
17,401
32,938
Pekin, IL
So does one of them get better signal then, as it’s larger reflector?
No, actually, on a .4 Eastern Arc, I can never get all 3 sats dialed in properly. The only thing a larger reflector does is improve rain fade but in this case, it's only slightly larger
Reactions: dishdude
JSheridan
8,899
10,028
USA
Yeah, I read that 1000.4 which has larger reflector isn’t compatible with hopper 3 as hybrid LNB only is for 1000.2
You can use a Hopper 3 and a 1000.4 dish but you also need a DPH42 switch.
I've always gotten slightly better numbers on eastern arc from a 1000.2 than a 1000.4.
Reactions: HipKat and dishdude
