How can I have a Joey more than 200ft from the hopper?
Joey123
Dec 15, 2014
17
Hi
Hello,
I'm trying to run my Joey about 250 to 300ft from the hopper using coaxial. Do I need an amplifier? The Joey will currently show a picture for about a minute then display an error message. Thanks for the help.
JSheridan
8,899
10,028
USA
Probably won't work on coax. You might be able to get that far running it on ethernet, but that's not officially supported by Dish.
Reactions: TheKrell
Scherrman
15,555
9,951
Eastern Iowa
Is this going to another building that it's that far away? If so then maybe you can relocate the dish antenna in between the buildings to cut the distance down.
Joey123
Dec 15, 2014
17
Hi
It seems like it's so close because it shows the channels and a pictures for about a minute then stops. Should I try an amp? If so, which one? Thanks for the help.
Joey123
Dec 15, 2014
17
Hi
Yes it is another building. Moving the dish didn't think of that. Good idea. That would work but would require the most amount of work so that's last resort but nice to know that option is there. I have already run the rg9 coax and I do have a cat5 wire and router there connected to the internet/wifi there but would prefer not to have to deal with internet protocol nightmares. Its probably closer to 200 to 250ft from the hopper. It seems so close to working.... Thanks
Joey123
Dec 15, 2014
17
Hi
Actually I'm not sure moving the satelite dish will work because that won't change the distance because the hopper and this Joey. Is it the distance between the dish and the Joey? or the distance between the hopper and the Joey that is most likely the problem? Thanks
TheKrell
A mighty and noble race originating on Altair IV.
38,817
46,477
Fairfax, VA
I agree with your assessment. The location of the dish has little bearing on your Joey issue; it's all due to the length of coax between Hopper and Joey. I am dubious of an amp helping either, since most amps work only on broadcast frequencies, and the Hopper/Joey moca signal overlaps but it's somewhat out of that band too.
TheKrell
38,817
46,477
Fairfax, VA
If your Hopper is on the same network as the 'wi-fi' in the remote building then just plug the Joey into that router in the remote building. Done.
I think this is the most promising approach, assuming you have a switch and not a router out there. If memory serves, you should be able to go 300' with cat5.
JSheridan
8,899
10,028
USA
I was picturing a router in switch mode because he said wi-fi. Thanks for clarifying. :)
Joey123
Dec 15, 2014
17
Hi
That would be great if the cat5 worked that easily but to get wifi in the remote building I have 3 routers daisy chained. The router in the building receives it's internet from a router in the middle of the house, and the wireless router in the middle of the house gets internet from the main modem in the garage where the hopper is located. Will plugging the Joey into the router in the remote building work? Or no because is on different network? Thank you
kevinsickles
171
Same network means same DHCP server for IP addresses. Are all the devices using the same subnet IP address for example 192.168.1.xxx
Joey123
Dec 15, 2014
17
Hi
Moving the hopper would solve the problem but a pain. Thank you
