Do I understand correctly that you can access and play video on your PC via an ethernet-connected receiver?Mediashare Video Support: You can now access video files from your PC.
When you do the search nothing is suppose to come up. However, the 30 skip should be enabled.
In the left hand column of the channel guide, inow have a handful of opaque channel boxes. What's that all about?
Is there something new about the 30-secondskip? I had it with the little right arrow button. Isn't that where it is now? I haven't checked if I have the new download yet, but wonder what has changed about the 30-second skip
those are channels you do not receive i believe.
i tried searching for "30SKIP" on a keyword search and it finds nothing. how can you change from the default (slip i imagine is the default)?
Got it today and they really went backwards on one thing, the To Do list. While in My Playlist, you used to be able to press the Yellow button to see what was going to be recorded. Now you have to go to Menu - Manage Recordings - To Do List. Why didn't they just add it to the Yellow popup menu?????
Has anyone experienced your HR20-700 locking up since the new software was installed? I've had to reboot both of my HR20s several times since the software came down on Thursday. Prior to that, I think I only rebooted once since signing up with D* last September...
I think the minor confusion on activating 30 second skip.
To switch between 30 second skip and 30 second slip is to go to menu, search for shows, keyword and then type in 30skip (no spaces) and continue. Then click all, when no results found comes up, click done. You set your receiver to 30 second skip. If you want to set it back to 30 second slip, follow the same procedure. Now that I played, I put 60skip and am trying to figure out if this works or not. I don't think it does, I think it stays at 30 seconds.
Jim
That is unusual, this software was in testing for months and was very reliable. What is happening that you have to reboot? Is it freezing, getting slow, etc? Anything you are doing that causes the problem to recur?
Hopefully we can help![]()
Nothing out of the ordinary. Watching any given station and when you go to try and use the guide or change the channel, it freezes up. It has also happened while watching recorded programs as well. I was quite surprised myself as I know this release was tested quite thoroughly. We've gone one day now with no reboots, so hopefully we're back on track.
