The 721 is doing MUCH better now and has for a while now. You will have to reboot it once in a while though but for the most part you should not have any problems.
I assume the LNB's are singles. I got the first in late-1998 with my initial install and the second ~2 years later with an ungrade to Dish 500.BobaBird said:If your 2 separate LNBs are really singles, you will have to replace them with duals and add another SW21 switch (what you called a combiner) and another line into the house.
I perceive a chicken and egg delemia here. According to the Tech Notes in your link, see below, last bullet, The DPP twin requires a software upgrade to work with the 721. Since software upgrades require a satellite link which requires a working LNB, how do we get there?You could also replace the separate LNBs with either a legacy or DishPro Twin, and run another the house. Or do as Shaggy suggestedand get the DP Plus Twin (info and diagram). That will save you from running another line and allow you to add another satellite some day without having to add an external switch.
721 is SD only. It will become a paperweight about the same time as all the other 3xx and 5xx receivers become paperweights, which I suspect is not anytime soon.chaddux said:Soon, your 721 will be useless anyway. With the switch to MPEG4, a 721 wouldn't work anymore. The first MPEG4 receiver is supposed to roll out next month so be aware that you are purchasing a soon-to-be paper weight. DISH hasn't revealed exactly how they will handle the switching of receivers so you might not be able to simply swap a 721 for an MPEG4 receiver.
