I don't even think the audio codec is displayed. If it is, please let me know where just in case I missed it somewhere among the OSD screens.Video codec as in H.264, MPEG-2, MPEG-1 is what he means. If Audio codec is displayed, why not video codec?![]()
I forgot to mention in my other post that version 3.3 still doesn't fix the screwy AUTO resolution thing. For you to get it to work smoother, you need to change the resolution from AUTO to something else (I have mine set at 1080i_30 to match my 1080i HD monitor max resolution). I don't know if you are using an old style NTSC tv (480i suggested), a typical low-cost HDTV monitor (720p suggested as most of those do 720p at best) or if you have a 1080 line capable HDTV monitor in which you might want to try a 1080i setting. I set mine away from AUTO after going to 3.3 and it works like a champ again without any screwy flashing or blanking or loss of HDMI stream.The new file is exactly what I was looking for, the only main issue I have is when the receiver changes from sd to hd or hd to sd channel, there is a split second of glitch as it changes between the different video resolutions.
with version 3.3, there are now a few features in the Manhattan that the openbox doesn't have so it is up to the individual to determine if those features (plus better support from users and potentially continuing from the developer) are worth the extra money. I highly doubt there is going to be a price drop considering who the importing seller is and their history of healthy profit margins.Now that the manhattan, in my opinion, is basically at the same level as the openbox the price of the unit needs to be lowered in order to stay competitive.
I'll try the timeshift OFF and see how that does. I've never gone into the record or PVR area of the receiver before so it should be fun.As far as question number 2 is concerned.... When a receiver is flashed, it sets the dvr a certian way. The "timeshift" function is on by default. That is why you see the change in the function of the info button. To change that, go to the DVR settings and turn that feature off. Then it don't make any difference weather a stick or drive is plugged in or not. The info screen will be back to "normal".
I didn't report possible format issues, I'm just concerned there may be with the editor so old and the receiver so new. It's hard to think in about 4 years there haven't been some tweaks to the internal receiver database format to add fields for new sat technologies (i.e. DisEQc but that's probably been around long enough to have been planned for in the receiver channel database).That said, the editor has been around since 2007 so to me it is no suprise there are discrepencies.
I think it's important to know at a glance what the feed may be using and I like how the Opensat has the info about video codec used, audio codec used, and resolution right there at the first press of the INFO button.May I ask what the importance of the codec info?
I forgot to mention in my other post that version 3.3 still doesn't fix the screwy AUTO resolution thing. For you to get it to work smoother, you need to change the resolution from AUTO to something else (I have mine set at 1080i_30 to match my 1080i HD monitor max resolution). I don't know if you are using an old style NTSC tv (480i suggested), a typical low-cost HDTV monitor (720p suggested as most of those do 720p at best) or if you have a 1080 line capable HDTV monitor in which you might want to try a 1080i setting. I set mine away from AUTO after going to 3.3 and it works like a champ again without any screwy flashing or blanking or loss of HDMI stream. with version 3.3, there are now a few features in the Manhattan that the openbox doesn't have so it is up to the individual to determine if those features (plus better support from users and potentially continuing from the developer) are worth the extra money. I highly doubt there is going to be a price drop considering who the importing seller is and their history of healthy profit margins.
Is there a place to edit the individual channels. I outputted from the Manhattan to my USB stick the 3 different BIN files. I opened the USER DB with the channel editor a few minutes ago and all I saw were sats and tp's. I didn't see the channels in there. I assume the individual channels might be in one of the other two BIN files and I haven't opened those up yet to see.1) I know that the posted editor does not accurately reflect the Diseqc switch state, but I've recently used the Editor to edit the sat positions, and that went without a hitch.
I'll have to look harder. I know the HD resolution feature was mentioned in the updated/change log for 3.2 but I could never find it on the OSD. Let me try again on 3.3 when I come across one of many easily found HD feeds this afternoon.3) The video resolution IS displayed except in the 480i instance. Get on a HD channel and you'll see it.
I may have a audio mux limit request change, but first I have to see if 3.3 increased the number of audio channels that can be written to memory when one tunes/listens to those huge audio distribution muxes.All I know but keep those suggestions coming in.Keep Jeff Schumann's programmer busy !
Thought we could start a new thread about reaction to the Manhattan 3.3 update, date 30 Sep 2011. I've loaded it on two receivers, and am happy to see the 22khz control in all motorized and fixed menus. Haven't found any issues, yet.![]()
Yes they are, and 22khz control, too. Your Uni lnbf can now be 10600, 22khz ON, and so can mine !![]()
Jim,
See Greg Harris' note above about Diseqc 1.2 and 22khz together. I can't check it easily with my setup. Do you use them together ?![]()
There is no way that the receiver could detect circular or linear, but it IS interesting that it's reporting the feed as PAL. Hopefully, Stone will send this on to Jeff Schumann to look into. Or you could email Jeff yourself. I can just imagine the list of stuff he has to look at, but he DOES look at the stuff, and try to prioritize it.It's not a problem at all. I just thought it quite odd that PAL would show up instead of NTSC which they are. This has come up on all circular sats I have scanned; maybe the receiver gets cofused with circular tp when scanning with a linear feed.
