Maybe New Software Update in May
kirkdj
172
I got news that the new OTA scanning ability might be implemented in mid-May...I sure hope it's soon! I sure hope they address some of the bugs too!
"Scanning is in the next release which, at the moment, is looking like mid-May.
Wilt"
:shocked
Yeah, I need the scanning so I can tune NBC. My local is giving me hideous multipathing and won't lock, so I need to tune the Springfield one.
How is scanning going to work?
Hi:
I don't understand how scanning is going to work. I have a large directional antenna with a rotor and I need to rotate the antenna back and forth to get all of my mapped channels. Will I need to scan at each antenna position to get all of my channels mapped? Also, how is the Program Guide going to know which channels I have mapped? I think one of the main advantages of VOOM is that it integrates both the OTA and Sat signal into one comprehensive guide. I don't mind the current system where you call VOOM to have a channel added to your mapping as you really only need to do it once. It would be nice if you could make the request via their web site and if you could have channels deleted from your map as well.
Sincerely,
Joseph
jnardone,
once you scan your channels, it will stay on your PG. You can always delete or add them to your PG. You can still your rotor the same way. The manual scan just provide a way to add or delete channels over the air that are near you. Much better than the current system of mapping.
jnardone said:
Hi:
Except that sometimes it just doesn't get added. I'm still waiting foe my WB to be added to the map -- self-scanning will make this much easier.
More like "INSANELY better than the current system of mapping."
Look how big the "OTA problems" thread is. Voom should have had scanning from the get-go. It is nice that this is coming sooner rather than later though. I'll finally have KNWS, which is like the WGN of the Houston area. :)
Scanning
Hi:
I see, but how is the Program Guide going to know which channels you have self-mapped? Does it download the info for all available stations in the US and only display the ones mapped on your box?
Joseph
jnardone said:
Hi:
Joseph
Yeah that might be a two part problem. One is the manual scannig. Once in place the PG might not have the PG information for those stations not mapped in software to your zipcode. They stil might need to continue mapping those stations which I think is easier because is just PG data and not related to the actual tunning of the channel.
Since they pull their guide data from Zap2It, it should be relatively simple to populate the distant locals data. The Zap2It guide includes channels that are a LONG way away from me as local.
-MP
What Do I Have To Lose Switching To Voom?
Aspect Ratio
