Must they install THEIR antenna?
mike528
78
DC area
Sure, you can keep your old antenna. The installers will be happy to leave it alone and only install a new dish. That was my experience, anyway. I already had a good antenna with a rotor in place. The installers said they got paid the same, but had less work to do. They did leave me with the Stealth and associated amplierfiers, because I'm "entitled" to it as a Voom subscriber, and because Voom might ask for it back if I ever canceled. (I stashed the Stealth, still in its box, in the back of a bedroom closet.)
Bierboy
May 25, 2004
6
East Moline, Ill.
Thanks. That's what I figured, but, before I made any moves, just wanted to check. It makes sense they'd leave well enough alone. From what I've read on this and other forums, their antenna setups have really been hit or miss.
mike528
78
DC area
Yes, they have been hit or miss. But if you are getting good OTA with your old setup, you should get good reception if you use that same antenna with Voom. I had been using a 2.5 year-old Mitsubishi box for D*, and when I plugged the old antenna into the new Voom box, I found I got the same channels as before, but reception was more stable, channels were a little easier to tune, the antenna did not have to be pointed quite so exactly in the right direction, etc.. OTA tuners seem to have improved -- or at least Voom's is an improvement on my old Mitsu box.
jrM
Feb 29, 2004
25
Bierboy said:
Quick question - if you order VOOM, must you install their antenna :mad: ? I already have a great OTA HD setup, and I don't want anybody screwing with it.
what antenna do you have i have no luck with this stealth :eek:
Bierboy
May 25, 2004
6
East Moline, Ill.
I'm using a Channel Master 4221, four bay since all my HDs are UHF. It's on a 25 foot mast with rotor. I'm only about 20 miles from the antenna farm, though, so I don't have any reception problems. I'm splitting the feed to my Sammy SIR-T151, and to my antenna B coax jack on my Hitachi 51UWX20B. That way I get my HDs through the STB plus I can get my OTA analog stations if the cable goes out. And, with the rotor, I'm picking up some fringe OTA analogs about 40-50 miles out.
