Pole mount I could definitely do.By ground mount I meant on a pole mounted into the ground.
...as opposed to mounted to a roof or the side of a house.![]()
Samsung Galaxy S6 Active
What would I need for Cyou can get the freesat V7 for less than 30.00 on ebay.
just buy from someone that has the USA power cord.
Spend the extra money on a good dish, Geosatpro is a very well built KU band dish.
as FaT Air said look for a C Band dish, thats where the good stuff is at.
Min 6ft preferably 10ft. I got 2 old Primestar (channelmaster) Ku dishes years ago, both out of the trash.What would I need for C
band?
I just bought it, I also got 30 days Free Amazon prime lol.The V7 is now on Amazon Prime.
Yep thanks.FWIW: might check www.dishpointer.com to check your LOS. Use the obstacle checker tool. Place the marker on the suspected obstacle and read out the height at which it may interfere.
FWIW 2:
my 'farm'
On the dish, I'm assuming Linear lnb is a Must for FTA?
Circular is Directv and Dish LNBS correct?Linear is what you want. Linear - PLL - Standard.
as apposed to Circular - non PLL - Universal
Correct at least for NA.Circular is Directv and Dish LNBS correct?
:upDish pointer Pro app
Only reason I asked, I have 1 DP or DPP single LNB (can't remember off hand). I didn't know if at some point I could use it at add on."Do they all work?" is the most common question.
Most common answer is; "Yes"
All domestic FTA is linear. Domestic Ku is 11700 to 12200, Standard LNBF. C band is 3700 to 4300.
FWIW: Some international (Atlantic) Ku is below 11700 (Universal LNBF) And some are circular on C band.
:up
Does C band still offer Paid Packages?Second most asked is "how many channels and how much does it cost?"
"Near 2000 and nothing" is the answer.
(Jaws drop)
"you must be stealing it"
"Nope, Free to air, they're FREE".
Thanks for the tip.I'd call it done. But there's Manhattan Digital and Programming Center working on keeping it alive.(with new equipment)
Discussion on another site.
WARNING: Rainier Satellite is NOT to be trusted.
Try ths one, Vendor is a member here:Only reason I asked, I have 1 DP or DPP single LNB (can't remember off hand). I didn't know if at some point I could use it at add on.
If not I may put that up for sale too.
