Hello, someone of you used or knew this model of lnb I am looking for information but I think I was an old model
ok
and
PF9650S PANSAT Stacked C-Band LNBF
compared to titanium WiMAX
yes more thisDo you have a receiver(s) supporting the OCS type of polarity selection? Do you require the higher stability of PLL or signal filtering of adjacent / high amplitude out-of-band signals that could swamp the conversion?
Of these feed horn which will be the best, I suppose that one of these and a norsat 3220 and Microwave Noise Filter is better than titanium to filter interference,
since I have a titanium wimax I worked for 3 months but again I lost the signal in the whole arcView attachment 136282 View attachment 136283
I already have 3 lnbs titanium new 2 decos 1 pc tuner cables newI wouldn't make that bet myself. The Titanium PLL LNBF is very good. There are a lot of reasons you could lose signal on the whole arc and the LNBF is only one of them, and it is less likely than bad connections, bad switch, bad pointing, and general human error. Having a spare LNB and a meter will help answer that.
I wouldn't dissuade someone from buying a different gadget, but not before determining the problem.
ok
and
If the interference is not addressed by the Titanium C1-PLL, then the interference is within the downlink frequency range and the choice of LBNF, LNB or waveguide +/- band edge filtering will not make a difference.I do not say in titanium is the problem, but it is pure interference,,that titanium 3.7 can not with this
a friend told me that the same happened to a titanium and another lnb, he spent a year fighting until he lowers his antenna from the ceiling, the position on the floor and his problem disappears
they also recommend me
cage faraday
cage faraday
I have a problem with the 3820 H 29720 3/4 MUX on 101W (SES-1). The signal on this MUX just bounces in and out. Everything else on this satellite will scan in, but not this one. I've bumped the frequency up and down a few Mhz and tried changing the symbol rate as well. It just won't lock. I'd like to put a WiMax LNBF on this dish, but the last time I checked with Titanium, these weren't available in dual output.![]()
Already on the ocean, and they'll be here inside of a month!
