Official 622 L4.01 Discussion Thread
Ok another update sent to the beta team.
Just a further update, I went into the system info screen again (to see if there was anything new in the screens) and this time I got an ERROR message which I did not get the last handful of times I went in earlier. (see bug4.jpg and bug5.jpg)
However running check switch it is still not showing 110 on port 2.
My wife has left the house for another meeting, however I will leave my office early and will go home and will do the following…
1) Unplug power from the 622 for 5 minutes
2) I will check if 110 is working on the other receivers
3) I will check the Dish with my Birddog meter and re-peak if needed.
4) If 110 is working on other receivers I will take the 622 and place it where the other receiver is, this will check if it’s a cable or DPP separator issue.
I will then report my findings to you when I have them. I will leave my office at 3:45pm eastern time.
Weather here in Connecticut is currently slightly overcast and the temperature is 39 degrees.
Scott out. :)
PiP- did not work with the L401 for me in the dual mode TV Screen but works in single mode, i dont know why everything else seems to be fine.Is this how it is supposed to be?ANYONE.
Not in the Beta Test team, put TV on Martha to get ready for Local News on Mpeg4 channel (Kob) screen went black and heard static... remote unresponsive, power button re-boot ineffective. I had to pull the plug and wait till HDD spun down, at the acquiring signal screen now, just got programming back...
I woke up this morning and flipped the TV to the warning of a corrupt drive and I would need to erase the drive. I had not signed up to test and have not confirmed if I have 4.01. I secured my system and went to work. Hopefully all will be well after a reboot, and that I have 4.01!
Miner
Here is a problem for me. I don't like seeing duplicate listings so if I have 2 channels that are showing the same thing I lock one out. Did this with the HD channels in the 9000's that are mapped down to 100's and 300's. All was fine till I did a search for an upcoming program. Didn't work. So the mapped down lower number follows from the older 9000 number. It just messy to see the same listing 2x for the same thing on 2 different channels. It doesn't work that way for locals if you have the channel in the 6000's locked out so it should be correctable.
Hmm....I'm beginning to feel thankful I didn't put my name on the early adopters list.....
Neither dfergie or I put our names on the beta list, but it spooled nonetheless.
Sounds like they are taking the Microsoft approach. Just spooling new software, even if it is buggy. The customer be damned.
BUT So far so good; no "blue screens of death" (so to speak) ;)
It also seems the "Pause bug" from L3.65 is gone. I tested it on live tv, and it worked normally.
One thing I don't like is that the HD channels take over the SD equivalents. Ok for NFL Net, which runs the same stuff on both channels, but not ok for Food. I'm gonna have to find a way to fix that, or else face hell at home....
Late start recording Criminal Minds Wed. 4/11
Cuban Baseball on HDNET?
