Hey all,
I finally took the leap and bought a proper pcie tuner card. I just installed a TBS6902 dual tuner card to go along with my two WinTV ATSC tuners and WinTV Nova. Ideally I'd like to have both FTA and OTA in one program that can DVR them.
I've been using Windows Media Center for several years for OTA. It should technically work with the TBS card, but would have no program guide, and no manual recording settings. I've also been trying out SichboPVR, which is working for the most part but won't drive the HH-90 for some reason. The card CAN drive the motor using DVB Dream, so the issue must be Sichbo related (have been tweaking its settings with no luck).
Does anyone know of a relatively easy-to-use program for both FTA and OTA? I don't care if it's a pain to set up, so long as it's easy enough for the wife and I to operate after it's set up.
And, since everyone loves photos...
Two ATSC tuners (one USB not pictured), two DVB-S2 tuners, one DVB-S tuner (ha!), blu-ray burner, four hard drives, and one solid state drive. I think I need a bigger case!
) that seem to have a problem using a remote if they have to press more than one or two buttons to get to what they want to watch. If your family members call you to tune the channels on the TV for them, then nothing you use will be easy enough for them. It's not rocket science, but if someone has the mindset that they shouldn't have to learn how to control the TV, then about all you can do is connect the TV to an antenna and tell them "you get what you get", unless you want to be the TV navigator in your family. But if your family members are reasonably intelligent people then controlling Kodi shouldn't be an issue once you get past the initial learning curve, and really the biggest learning curve is for configuring the PVR backend; Kodi is pretty easy to use once you have the proper PVR addon installed and configured (particularly if you pick a decent skin, which would NOT be the Kodi default IMHO). Note that MediaPortal also has its own frontend software, so you don't necessarily need to use Kodi with MediaPortal.
