Quattro LNB
David Marshall
Aug 7, 2019
South Carolina
Howdy!
We’re trying to set up an Orby TV system for 32 receivers. I’m totally new to the satellite game, but upon further research, I’ve found that I’ll likely need a quattro LMB with cascading multiswitches. Does this make sense, and if so, can you point me to an LMB/dish combo that I can use to get things up and running?
I purchased the Orby dish, but the LMB won’t support 32 receivers (to my knowledge). I’ve attached the photo of the LMB that came with the self-install kit.
Thanks!
David
No need for a multiple output LNBF as the Orby channels are on a single polarity.
Use a powered satellite splitter 1x32 (or higher) to feed the single output LNBF to multiple receivers. Could also use a 1x2 power passing splitter that is feeding two 1x16 amplified splitters. If the splitter is non amplified, a quality inline amplifier may be necessary to provide adequate signal strength through the 14dB+ of attenuation caused by the splitteres.
BlonderTongue has a good selection of appropriate splitters. The splitter frequency rating must be at least 2300MHz.
For 32 STB distribution, I would use a 1.2m dish and matching Standard LO (10750) LNBF. This would increase signal reliability and provide a higher SNR for distribution.
I had missed an obvious distribution solution as I focused on inexpensive splitters. Use a 2 way splitter to feed the vertical input port of two Blonder Tongue SMR-1600 2x16 multi-switches.
An inexpensive switch option with significant signal loss would be to use DirecTV switches. One SPLIT4MRV DirecTV 1x4 switch feeding 4 - SPLIT8MRV DirecTV 1x8 switches). No extra power supplies should be needed in this configuration.
A preferred method with no signal loss example would be to use a Quintech 32-Port LS32-2150A active L-band splitter - Expensive, but a commercial option.
Hope this helps!
