Replacement SIM, Orby DVR
dogshowaddict45
Apr 1, 2021
Texas City, Texas
I’m still wanting to watch the recordings I got through Orby Satellite, and then antenna programs *since*
But I just broke off the back end of my SIM card and it’s not working. Any ideas on a new one?
Thank you.
primestar31
13,567
14,029
Beta Omicron Delta III
Most likely married to receiver. You are SOL IMO
Sorry friend
THIS. Your recordings and such are gone, unless you have a razor blade, microscope, and a way of repairing your sim card. I've done that in the past for another company, though I'm a trained electronics tech with 50 years of experience. IF you know somebody with real good skills of soldering and such, you MAY be able to repair it, depending on how it broke.
Reactions: bmj11
TV Junkie
477
430
West Coast
50 years?! Wow you look so young in your profile pic! Those must be vampire fangs I see. Immortal youth!
  • Haha
Reactions: raydio and trojan67
FTA4PA
Satellite Guys Family
7,621
5,952
Central Pennsylvania
Thank you.
With Orby out of business they won't be of any help. Probably a long shot but you may be able to remove the drive from the receiver and use some form of software on a pc to extract the recordings. I don't have the DVR model myself so can't say for sure.
TV Junkie
477
430
West Coast
No, got parts out of old electronics, and hand-built radios and such. My first was a crystal radio built in an old cigar box at age 7.
At only 7 it must have taken you quite some time to smoke all those cigars!
Corrado
2,428
303
Hudson Valley Region, NY
I already repurposed the 500 gb HDD for one of my work laptops from the DVR receiver. I experimented some with it but finally moved on. Not hopeful of any other use for the box. I couldn't get past the setup wizard. I think mine was an open box Best Buy return.
Anyone else with a previously activated DVR model still able to view recordings or create new ones?
Reactions: Skyscanner
Mario Lombardi
On Vacation
Mar 13, 2021
44
32
Toledo Ohio
It’s worth a shot. Go on eBay and buy a new Orby receiver with a virgin card.
Take the virgin card and put it in your receiver, and see if it works.
Although I never had Orby, I would imagine your probably getting an error message to insert your card. A virgin card would likely work, as it would stop the error message, and I don’t think Orby was never advanced enough to tie their DVR service to a subscription.
If you couldn’t find an Orby card, thinking out loud, I believe Orby did use nagravision. I would cut down a dish card and try that if you had one laying around. Doubt it would work, but worth a try.
amstereo
Aug 2, 2021
29
29
Eastern Pennsylvania
Thank you.
Have you tried running your DVR without the SIM card installed? My new-in-the-box inactivated ORBY TV DVR receiver bounced to life for the first time a few weeks ago, after I was able to get past the setup screen wizard. My DVR is functioning on both OTA satellite and my local broadcast TV channels. I removed the SIM card, and it did not make a difference. I also put in a different SIM card. Other than reading the new serial number, it did not change the way the receiver worked for me. I don’t know what happens when using formerly activated ORBY TV receivers.
amstereo
Aug 2, 2021
29
29
How did you get past the setup wizard amstereo ?
You will need a working satellite feed from 116.8W to your inactivated ORBY TV receiver. Then the receiver sails through the setup wizard, performing some kind of scan at step seven, then the local broadcast channels get scanned, then the successful completion message!
Cjmcinc
Dec 28, 2021
34120
Yes I can watch and record but not on satellite channel only local
amstereo
Aug 2, 2021
29
29
Public statement:
Orby is excited to re-launch under new ownership! Our initial, family-friendly package is supplemented by Elevate, a faith-based package.
In addition, we are in discussions with every major programming group from the previous Orby platform.
We’ll be offering a wider selection soon – featuring most of the original Orby programming.
Please direct any inquiries to info@orbytv.com and we’ll respond as soon as we are able.
