Sadoun Satellite Signal Meters for all installers
Sadoun
2,320
Columbus, OHIO
Novice level……………………
SF95 DBS DSS analog signal meter
Simplicity at its finest! A simple meter for the self-installing consumer. You can connect right to the dish to fine tune your satellite antenna quickly.
SF95 analog meter kit
A great simple and inexpensive solution for permanent or portable installs for the home user. This kit has a battery pack so that you can be setting up the dish even before the cable is run or the receiver is set up. Nice for campers or tailgaters!
Intermediate Hobby level…………………..
JVI-10 dual analog meter
Need a great meter at a low price? Lots of function testing in a simple package. Can be connected to 2 lnbs at once for accurate signal strength fine-tuning and testing. Great for the hobbyist. Rechargable battery pack. Great for WildBlue, DISH or DirectTV tailgate set-ups too!
PVS F3 dual professional analog meter
Installer on a tight budget or just getting started? This meter can align 2 separate lnbs at the same time! Vertical and Horizontal polarity testing, 22Khz test, mA reading. Comes with rechargeable battery pack and charger.
JVI-10 digital Handheld signal meter.
A great starter digital meter for a new installer or hobbiest. Works with all DVB signals and gives an easy read-out of signal strength. Works in cold weather! Car and AC charger included.
Professional level…………………
AccutracPro22
Super sleek design, a MUST HAVE for all professional installers. A duel digital battery operated meter that fits in your pocket. Duel precise signal strength readings at once. Built in cable tester, 22Khz, receiver output voltage and more! Extremely handy for duel LNB alignments. Great for DISH and DirectTV quick checks, Turroidal systems or any multiple lnb configuration that fits on your belt or in your pocket!
The Accutrac-III
Well known among professional installers, this meter has a lot to offer at a reasonable price. Able to receive both the Ka-band and Ku-band signals. Data port on the meter allows the Acutrac III to remain flexible with future expansion
The Birdog Satellite Identifier
A superb choice for rack-mounted satellite identification. Also can be used hand-held. Reads circular and linear lnb systems for subscription services or Free-to-Air. Holds up to 32 satellite IDs and can be configured to meet your needs. Runs on AC or battery. Great for up-link trucks, Installers or the Advanced satellite enthusiast.
The SatHawk 4000
The latest and greatest from England. Positive confirmation of Satellite. Holds up to 120 satellites in its memory! Never gives a false identification. Have the option of vertical and horizontal transponders listed separately. Standard or Universal LNBs. Powerful battery pack will support DISHProPlus lnbs! Datafiles categorized for easy listings. It even has an lnb test function. Will also operate right off the charger. Great for HughesNet, WildBlue,DISH,DirectTV,FTA all KU and C-band systems. This meter is absolutely for the professional who needs lots of versatility!
Precision level………………………….
The Satlook Mark III Spectrum Analyzer
Swedish made Sat-TV Instrument and Spectrum-Analyzer. Professional use when high accuracy and precise information is needed.
The Satlook Digital Spectrum Analyzer
Easily operated without a lot of unnecessary buttons and knobs this unit can handle anything. Sat-TV channels can be tuned in and viewed upon (Multistandard Video PAL, NTSC and SECAM). Audio frequencies between 5.5-8.5 MHz can be listened to. The Spectrum can be extended (zoom in) for correct adjustment for the polarization ("cross-polarization"). The instrument has very high resolution and accuracy. It presents measured data _+2 dB (at around 20 C.)
THE COMBOLOOK
A Swedish, precision made SAT-TV/CATV instrument and spectrum-analyzer. It is a combination of SATLOOK Digital NIT and TVLOOK in one unit. The unit is made for exact alignment and adjustment of satellite-dishes, aerial antennas. It is also an excellent tool for working with Cable-TV networks. It is intended for professional use when high accuracy and precise information are needed. It's easily operated without a lot of unnecessary buttons and knobs. The basic functions are easy to get a hold on and takes only minutes to learn. Has all the functions of the other two combined!
An there you have it, from Sadoun Satellite Sales :D
