If you are losing signal due to signal loss due to RG-59 cable and long cable run, you can test the cable all you want, it will always test fine. Problem isn't BAD cable, but most likely the WRONG type of cable. DBS Satellite specifies RG-6 only. If you are having a consistant problem, the best bet is to replace cable with RG-6.
