this tv
do you get anything on 87W
using that bandstacked LNB the frequency may be off depending on the LNB LO you have it set for. SInce most channels are horizontal it should be set for 5750
Getting ThisTV fine with a B1SAT. As Iceberg said, be sure your L.O. is 5750. Your vertical transponders (well, there's only one on this bird last I checked) will be off by 600 MHz. Horizontal TPs will be accurate.
