Understanding 5G: Measuring Signal Strength with the Wilson Pro 5G Network Scanner
Frustrated with dropped calls and sluggish data? Signal strength might be the culprit! This guide dives into using the Wilson Pro 5G Network Scanner, a powerful tool that goes beyond basic bars. It measures signal strength in detail, including 5G, to help you identify and optimise your cellular reception. Learn how to unlock the secrets of your mobile network and finally experience reliable connections. This blog post will delve into using the Wilson Pro 5G Network Scanner to measure signal strength and uncover valuable insights about your cellular environment. Whether you’re experiencing dropped calls or slow data speeds, this tool can be your secret weapon for optimising your mobile experience.
1: Introduction to 5G Technology​
The way we connect is on the cusp of a revolution. Buckle up as we explore the exciting world of 5G technology!
5G Explained: It’s the fifth generation of mobile network technology, the successor to the widely used 4G. Imagine it as a superhighway for data, offering significantly faster speeds, lower latency (response time), and vastly improved capacity.
Why is 5G Important? This isn’t just about downloading movies quicker. 5G paves the way for groundbreaking advancements in various fields:
  • Seamless Streaming: Plunge into the euphoria of smooth real-time gaming, video streaming at top ultra-high definition, and reality simulation without perceivable delay.
  • The Internet of Things (IoT): Smart homes, autonomous cars, and intelligent cities aren’t just 5G but also rise with it as it brings a boom in connected devices.
  • Enhanced Mobile Broadband (eMBB): Take advantage of the fast connection speeds to download excellent-quality files and watch the mode of accessing and sharing the data get modified.
  • Ultra-Reliable Low-Latency Communication (uRLLC): This is why 5G can cope with the applications developed in real-time such as car recovery systems and the operation of remote-controlled robots that need almost immediate response.
The Leap from 4G to 5G:
Compared to 4G, 5G offers a significant leap in:
  • Speed: Download speeds up to 10 Gigabits per second (Gbps), for example, will be many times higher than the 4G normal 100 Mbps.
  • Latency: The 5G boasts reduced latency dramatically, which means that increased interactions with no latency are possible.
  • Capacity: This also ensures that the network sustains a more substantial amount of connected devices at one go.
Get ready to experience a whole new level of connectivity with 5G! This technology holds immense potential to transform our lives and redefine how we interact with the world around us.
2: Features of the Wilson Pro 5G Network Scanner​
Looking to optimise your cellular experience? Look no further than the Wilson Pro 5G Network Scanner! This innovative tool empowers you to analyse your local cell signal in detail. Let’s delve into its key features:
Features at Your Fingertips:
  • 5G Savvy: Unlike older scanners, the Wilson Pro 5G Network Scanner is built for the future, providing a comprehensive analysis of both 5G (including C-Band and mmWave) and 4G (LTE) networks.
  • Multi-Band Mastery: It scans a wide range of frequencies, ensuring compatibility with most cellular signals relevant to boosting. Identify bands like 4/5/12/13/14/25/66/71/77 to understand your signal landscape.
  • Cell Tower Hunter: Say goodbye to signal guessing! This scanner helps pinpoint nearby cell towers from various carriers, providing valuable information for aiming your cell signal booster antenna.
  • Signal Strength Sleuth: Measure the strength of cellular signals in your area. This data is crucial for assessing if a cell signal booster can improve your reception.
Beyond the Basics: This scanner goes a step further than its predecessors by:
  • Seamless App Integration: It pairs with the user-friendly Cell LinQ app (available for iOS and Android) for real-time data display, geo-mapping of scan results, detailed reporting, and data export for further analysis.
  • Future-Proof Technology: Investing in a scanner that supports the latest 5G technology ensures you’re prepared for the evolving cellular landscape.
The Wilson Pro 5G Network Scanner is a powerful tool for anyone seeking to optimise their cellular signal, especially in the age of 5G.
3: How to Measure 5G Signal Strength​
Ever wished you could see your cell signal strength laid bare? The Wilson Pro 5G Network Scanner makes it possible! This guide will walk you through using this tool to measure your 5G signal strength and gain valuable insights.
Get Ready to Scan:
  1. Power Up: Turn on your Wilson Pro 5G Network Scanner.
  2. App Connection (Optional): For a more comprehensive experience, download the Cell LinQ app and pair it with your scanner via Bluetooth. This unlocks features like real-time data display and data export.
  3. Location, Location, Location: Find an open area with minimal obstructions for an accurate scan. Hold the scanner upright with the antenna pointing towards the sky.
Understanding the Data:
The scanner will display various metrics – don’t worry, we’ll break them down!
  • Signal Strength: This is usually represented by bars or a numerical value. Higher values indicate a stronger signal.
  • Signal Type: Identify if you’re connected to 5G (including C-Band or mmWave) or 4G (LTE).
  • Cell Tower Information: The scanner might display details like cell tower ID, carrier information, and signal strength from nearby towers (available with the Cell LinQ app).
Interpreting the Results:
The average characteristics of the 5G cellular signal give you an idea of its quality especially, 5G. Nowadays, clients get annoyed because signal weaknesses cause disconnected calls and slow data rates. This data is of the essence for finding out if a signal booster will work if affected by the case.
The Wilson Pro 5G Network Scanner empowers you to take control of your cellular experience. With this knowledge, you can make informed decisions to optimise your signal and enjoy reliable connectivity!
4: Interpreting the Results​
The Wilson Pro 5G Network Scanner equips you with valuable data, but what does it all mean? This section will guide you through interpreting the results and using them to troubleshoot signal issues.
Unlocking the Data:
The scanner displays various metrics, but the key ones are:
  • Signal Strength: Often represented by bars or dBm values (higher dBm signifies stronger signal).
  • Signal Type: Identifies if you’re connected to 5G (including C-Band/mmWave) or 4G (LTE).
  • Cell Tower Information: Details like cell tower ID, carrier info, and nearby tower signal strength (might require the Cell LinQ app).
Understanding What You See:
By analysing these metrics, you can assess your cellular signal strength, especially 5G. Here’s a general guideline:
  • Strong Signal: Repeating shaders or big bars would mean a strong signal that could be one good indication of better-than-average call quality and internet speeds.
  • Weak Signal: Showing 5 bars, or more than -70dBm, puts the signal strength less than ideal, making your phone prone to dropped calls, slow data downloads, and intermittent data connections.
Troubleshooting Tips:
Based on your signal strength, here are some troubleshooting pointers:
  • Strong Signal: You might not necessarily need a cell signal booster. However, the scanner can still be helpful for optimising your existing setup (e.g., antenna placement).
  • Weak Signal: A cell signal booster might be a viable solution to amplify your signal and improve connectivity. The specific booster model depends on your signal type and needs.
Need Help? We’re Here for You!
If you have any confusion regarding the data interpretation or if you have needed questions, feel free to get in touch with the customer care services of Solid Signal. They know all about the cues that cells send and will help you in finding the best answer depending on your situation. Solid Signal has over 20 years of experience diagnosing cell service problems.
You may wish to consider outsourcing options. If you’re a professional installer, you can leverage their resources and expertise to assist your clients with signal analysis and cell signal booster recommendations. This support outsourcing model not only streamlines the installation process but also ensures that clients receive the most effective and customised signal enhancement solutions, backed by Wilson Pro’s comprehensive technical expertise.
5: Case Studies and Real-world Applications​
The Wilson Pro 5G Network Scanner isn’t just a fancy gadget – it’s a powerful tool with real-world applications. Let’s explore how businesses and individuals are utilising this scanner to optimise their cellular experience:
Empowering Businesses:
  • Rural Businesses: Farms, remote offices, and construction companies can pinpoint weak signal areas, enabling them to strategically place cell signal boosters for improved communication and employee productivity.
  • Retail Stores: Ensure seamless customer experiences by identifying signal dead zones within stores, allowing for targeted booster placement to guarantee smooth credit card transactions and mobile payments.
  • Event Organisers: Festivals and outdoor events often have spotty cell service. The scanner helps organisers locate weak signal pockets and strategically deploy temporary cell signal boosters for uninterrupted communication and social media sharing for attendees.
Boosting Individual Needs:
  • Remote Workers: Working from home in areas with weak signals can be frustrating. The scanner empowers individuals to assess their signal strength and determine if a booster can enhance video conferencing quality and overall internet reliability.
  • Travel Enthusiasts: For those who venture off the beaten path, the scanner helps identify areas with weak 5G signals, allowing them to adjust travel plans or download content beforehand to avoid connectivity issues.
  • Gamers: Online gaming demands a strong and stable connection. The scanner allows gamers to pinpoint signal inconsistencies and optimise their setup for lag-free, competitive gameplay.
The Impact of Accurate 5G Measurement:
By providing precise 5G signal strength data, the Wilson Pro 5G Network Scanner plays a crucial role in various industries:
  • Improved Decision-Making: Companies and people can determine which cell signal boosters suit their situation best, through proper research, and thus not exhausting so much on the wrong ones.
  • Targeted Solutions: Precise spectrum monitoring enables the air of boosters to be in the right place avoiding booster redundancy and hence overall connectivity being better.
  • Enhanced Productivity & Customer Satisfaction: The higher the cellular signals generate stronger networks resulting in the improved quality of services that businesses offer and the customers’ satisfaction that is largely dictated by the mobile connectivity standards.
The Wilson Pro 5G Network Scanner is more than just a measurement tool; it’s a gateway to a better-connected future. If you’re interested in learning more, call the experts at 888-233-7563 or fill out the form below.
The post Understanding 5G: Measuring Signal Strength with the Wilson Pro 5G Network Scanner appeared first on The Solid Signal Blog.
Continue reading...
THROWBACK THURSDAY: When DISH owned Blockbuster
How do you know if something’s blocking your satellite or antenna signal?
