Urgent Testing Assistance for Galaxy 19 Temporary Transponder
SatelliteAV
6,486
186
Roseville, CA
5:30pm EST 3/18/2010 - Request from Uplinker and IntelSat Engineering
We urgently need your testing assistance for a temporary transponder currently Testing until 12mid EST today 3/18/2010.
  1. Please provide Signal Level and Signal Quality for these 4 transponders.
  2. Indicate if you peak SQ for 11842, does the SQ drop on the other TPs?
  • TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SL SQ
  • TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SL SQ
  • TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SL SQ
  • TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 -SL SQ
Minneapolis, MN
Coolsat 5000/Geosatpro 36" dish
11929-76
12146-75
11842-75
11960-75...actually bouncing between 72 & 75
no I did not peak on 11842. I am peaked on 11966 but even if I try on the 36" to peak on 11842 I dont gain anything quality wise and dont lose anything on the other...When one goes they all go
The 30" has different results
11842-73
11929-75
11960-75/76
12146-75
I am peaked on 12115...If I peak the 30" to 11842 then I lose quality on a few transponders like 11966
North Florida
Pansat 9200HD/1.0m Primestar
11842 73%
11929 70%
11960 60-68%
12146 68%
...Overcast skies today, so readings may be a few points low. :)
(Also this dish is fixed on G19)
Coolsat 6000 1.2 Meter
* TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 94
* TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 94
* TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 93
* TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 94
Same if I peak for 11842.
Fortec 90 cm, Coship 3188C
San Jose, California
11842 H SL 74.5 SQ 55
11929 V SL 75.1 SQ 54
11960 V SL 75.4 SQ 53
12146 V SL 76.1 SQ 55
2. Indicate if you peak SQ for 11842, does the SQ drop on the other TPs? No
Sacramento, CA / Clear / 72F / 90cm GEOSATpro
TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SQ 80 (peaked - Bump to west fraction of a degree)
TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SQ 77
TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SQ 55
TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 -SQ 75
TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SQ 65
TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SQ 80
TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SQ 70 (peaked)
TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 -SQ 80
Chicago on a 90 CM dish & pansat 9200
11842 H SL 71 SQ 58-61 fluctuating
11929 V SL 72 SQ 56
11960 V SL 72 SQ 10 -24 (fluctuating)
12146 V SL 70 SQ 44 & 58, It was at 44 for a moment and now is fluctuating between 52 & 58
Central Mexico / Clear / 84F / 90cm GEOSATpro
TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SQ 53
TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SQ 59
TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SQ 50
TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 -SQ 55
So Cal 93555 area code / China Lakes Naval Weapons Center / clear / temp 78°
GEOSAT pro 36" motorized dish
Coolsat 6100 private
Peaked on 11842:
TP6 - 11842 Polarity: Horizontal Symbol Rate: 22000 -SL SQ = 84%
TP11 - 11929 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 86%
TP13 - 11960 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 76 to 78% touchy
TP25 - 12146 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 86%
Peaked on 11960:
TP11 - 11929 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 84%
TP13 - 11960 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 82 to 84% touchy
TP25 - 12146 Polarity: Vertical Symbol Rate: 22000 -SL SQ = 85%
First peaked on 11842, I then had to jog the motor slightly EAST to fine tune 11960 which I found very touchy to peak. All of these TP's seem a bit touchy today as if the beam has been narrowed or more narrow than days ago.
97222 / Coolsat 6000 / Geosatpro 90cm / Geosatpro GSL1u / Wx: Sunny and Dry
TP6 - Frequency: 11842 Polarity: H SR: 22000 -SQ 70
TP11 - Frequency: 11929 Polarity: V SR: 22000 -SQ 72
TP13 - Frequency: 11960 Polarity: V SR: 22000 -SQ 70 (peaked)
TP25 - Frequency: 12146 Polarity: V SR: 22000 -SQ 70
TP6 - Frequency: 11842 Polarity: H SR: 22000 -SQ 73 (peaked)
TP11 - Frequency: 11929 Polarity: V SR: 22000 -SQ 73
TP13 - Frequency: 11960 Polarity: V SR: 22000 -SQ 67
TP25 - Frequency: 12146 Polarity: V SR: 22000 -SQ 69-72 fluctuating
31" fortec
TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SQ peaked 55 a nudge west
TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SQ 55
TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SQ 54
TP25 - Frequency: 12146 Polarity: Vertical Symbol Rate: 22000 -SQ 54
TP6 - Frequency: 11842 Polarity: Horizontal Symbol Rate: 22000 -SQ 42
TP11 - Frequency: 11929 Polarity: Vertical Symbol Rate: 22000 -SQ 46
TP13 - Frequency: 11960 Polarity: Vertical Symbol Rate: 22000 -SQ 56(peaked)
Milwaukee/Madison:
N-fusion HD 90cm WSI Inva SNH-031
11842 SL 99% SQ 53%
11929 SL 99% SQ 51%
11960 SL 99% SQ 70-75%
12146 SL 99% SQ 62%
No peaking of dish, dish is fixed to G19
Musher
I just tried peaking all frequencies requested on my unimesh 7.5 and i noticed as i nudged west i lost all signal on all fr's except 11842 .Mind you the sig dropped off quite a bit but hung there for , 4 more clicks ( west ) till it dropped on the GBOX.
Fortec Merc II one meter Fortec Dish
Freq SL SQ
11842 78 66
11929 80 64
11960 78 64
12146 77 64
Skywalker 1 slaved off of the Merc II
Freq SS SNR(dB)
11842 74 11.2
11929 71 10.8
11960 74 11.1
12146 72 10.7
Dish is already peaked on 11842
can´t pick G19
Can't pick up G19 Horizontal using satmeter, only vertical. Can't pick up on receiver 11842 h 22000,but 11960 v 22000 signal quality 54-58 . Leon,Mexico.
CS5K on an Andrews 1.2m:
L/Q
11842: 88/76
11929: 89/79 (peaked)
11960: 89/77
12146: 89/78
11842: 88/76
11929: 89/76
11960: 89/79
12146: 89/78 (peaked)
Genpix on an Andrews 1.2m:
SNR (dB)
11842: 11.4 - 11.6
11929: 12.1 - 12.2
11960: 11.1 - 11.2
12146: 11.6 - 11.8
Where to aim 2 extra Primestar dishes?
101 West
