GEOSATpro v box not working right
wildcat374
29
North carolina morganton
i have a vbox 2 with my geosat pro 3500 hooked up to it.. to turn my 7.5 c band bud it will turn manualy with the geosat box. but it will not turn it automatically.i have the geosat set on DiSEQC 1.2 when i turn to another sat it sens a signel to the v box. p12 or p5 i save it in the vbox and it still will not move automatically what am i doing wrong.
I have not had my 3500 hooked up in awhile but in there some where in the motor control is a place to save.
When you hit save you should also see the Vbox flash the same number showing it saved.
Good deal.
Since you already have the Sat positions stored on the VBox - You should be able to motor to each position with the VBox remote and THEN save each one in the receiver. that will save you having to find each Sat a 2nd time. (Speaking generically...I never has a 3500)
Or, With the controller disconnected from the STB, go into the STB's install menu and activate DiSEqC 1.2, assign the correct corresponding motor number then save. Once all satellites are activated, motor number assigned and saved, reconnect the receiver to the controller and they will work together.
