VIP 722k with Legacy LNBs?
chc59
95
15
Dalton, Ohio
I'm considering upgrading from a 221 to a 722K receiver.
I have all Legacy LNB's from 110,119,129
Can I split the one incoming line to go to the two inputs on the 722? I can't use the DPP Separator, can I?
Joe
Dish Pro LNB's and a DP 34 with two lines to the receiver would be the best, cheapest route. You need to post present antennas, if you have three dishes the DP34 will do the trick. Dish 500 is pretty simple, upgrade to a DPP twin and use a DP dual on second antenna, one cable to receiver and use the Separator. HD Turbo Dish is a bit more techno to aim, but the set up is much cleaner, still only one RG6 to 722.
