VOOM picture quality - DVI vs. component
1080iBeVuMin
915
Santa Rosa, CA
I just hooked up DVI, replacing component connection, and can see no difference. Or if do I see a difference, it is so slight that it could be my imagination.
My PQ is jaw-dropping gorgeous even with component, so I am not complaining. But I was a bit surprised to discover so little perceptible difference with DVI after reading so many posts that DVI is the "highest quality" etc. etc. Perhaps the difference varies depending on the display? I am running a Sony 34XBR910 (CRT) (my avatar).
Just curious, any thoughts about this? Anyone seeing major differences?
andrzej
Board Certified User
690
Boston subs
From reading hundreds of posts on AVSForum on the subject, you can conclude that the difference is minimal if any noticeable.Yea, my signature explains it well enough.
barth2k
592
I think that's because the CRT is an analog device. At some point, the signal is converted to analog for display, so either your STB does the conversion (component) or your TV does it (DVI).
If you have a digital technology like plasma or LCD or DLP, then it makes a difference.
neo0285
218
Thats exactly the case !
Charrasqueado
9
Pensacola, FL
I have DVI out to my Sony (It is digital) and component out to it also. I switch back and forth and have never seen any difference whatsoever. I was also expecting a big difference with the DVI cable, although I don't see how anything could provide a better picture... It is excellent.
flipper2001
106
South Florida
I have a D* HDTV box also and that is Component only, the picture appears sharper (because of thier PQ) but not as bright as voom (most likely because of the DVI input). I have plugged in my component cables (btw all monster HQ) into voom, but because it takes time to plug it in and walk around to the tv, its kind of hard to notice much of a difference.
desidoc
35
I agree but the picture in my toshiba 57h83 feels more sharp compared to component, in my IMHO. DVI Colors are a little bit washed out
desidoc
35
No I just did 56 point calibration myself and I also used DVE. for 1600 $TV , I can't justify to pay 300$ more for calibaration .Hopefully I will get plasma or a better display technology in 2-3 yrs. :smug
iceshark
533
Pacific Northwest
1080, I had a whole similar post on this subject. I have the 4.3 version of your tv. and I too was totally dissapointed with DVI on stock cable vs my components. My components have a more colorful crisper picture. Like the other poster I too noticed DVI colors being washed out.
Not complaining though components give me what i expect to have with HD till I buy another TV. Maybe Plasma maybe not.
Lobstah
444
Bottom line is that there are a LOT of people out there that were expecting a big improvement in PQ between component and DVI. On non-digital displays, I wouldn't expect any change, and for a lot of the people with digital displays, they're not finding much, if any, improvement either. As has been posted before, I think a lot depends on the quality of equipment/cables. In other words, if you have good stuff, component produces a PQ comparable to DVI.
Lob
cdelena
May 23, 2004
10
Dallas, Texas
It depends on the devices on both ends of the cable. I have an up-converting DVD player and an LCD RPTV where DVI is clearly better than component, but with my D* HD Tivo I see no difference to the same set. It sounds like the output produced by the Voom STB also may not be noticeably different from DVI to component. Mine is installed next month and I will report my findings.
DVD-Recorders
New to Voom - Antenna & Other Questions
