Why is this Happenning?
andyin137
369
Lompoc,California
For some reason,just in the past week my DVR is only recording the SD channel of Bio,even though I have set it on the HD channel,I checked whats its recording and its says the HD channel,but when I go to watch its the SD channel.Am I needing to adjust something???
harshness
18,892
4,066
Salem, OR
It seems likely that you failed to set up to record the HD version of the channel and chose the SD version instead. Try deleting the timer(s) and re-adding it(them).
You might also try setting up for channel 9443 as opposed to channel 119.
KAB
21,737
5,226
Fishers, IN
Perhaps is the program you are recording is not HD??
ClarkGable
185
92
NW Ohio
There is also a pull-down on one of the 722K record screens that allows you to choose HD or SD. Before you create the timer, there is an Options button on the right that lets you start and/or end the recording a few minutes early/late. That is where the HD/SD option pull-down is located. Check to see if HD is selected.
