WWV DOD Mars listener test message survey
Radioguy41
2,806
2,804
Lehighton, PA
They want to shut down WWV and WWVH and this is a way to determine if people are really tuning to and using it. Every response to the survey may help to keep it up and running.
"DOD Broadcast and Listener Survey on WWV and WWVH
From 14-24 August, WWV and WWVH will be broadcasting a DOD message at 10 mins past the hour on WWV and 50 mins past the hour on WWVH. As part of the message, all listeners are asked to take a listener survey at the URL specified in the message.
WWV Survey - DoD MARS
The results of this survey are shared with WWV/H personnel to show their NIST chain of command how often their stations are monitored and how the various timing signals and messages are used by the listeners.
Please take a listen to this message and take the survey...as the saying goes, "every vote counts" and your input to this survey is being used to help demonstrate the importance of these stations.
Thanks for your consideration in this effort.
Paul English, WD8DBY
Chief, Army MARS"
Reactions: k.r. and c-spand
c-spand
1,406
845
USA
I get the VAKN on 121w. Where is the DOD satellite position? Use to be the Pentagon ch. I have seen it listed before but remember i couldn't tune it at the time. Thank you
c-spand
1,406
845
USA
Oh. Like Emil Loutella says " Never mind". Was confused and thought you were referring to tv. . My bad.
N6BY
Geek
3,184
3,068
Roseville, CA 121W
Upon reading the thread title, my first impression was that this involved pointing our big dishes at Mars and listening for the WWV signal there. Maybe some day....
Reactions: c-spand
harshness
18,890
4,065
Salem, OR
I reported that I had multiple devices that used the signal as a reference (including my wristwatch -- AKA "Atomic Time").
Radioguy41
2,806
2,804
Lehighton, PA
I was finally able to pull it in at 15:10 UTC last night and even then it wasn't clear. Propagation must be really bad right now.
Jim S.
When someone asks you if you're a god, you say yes
5,669
1,291
FN11od
Are these devices using WWV, or WWVB? I haven't heard of plans to shut down WWVB, although I don't know how anybody picks it up these days with all the interference on the low-frequency band.
harshness
18,890
4,065
Salem, OR
Rumors of WWVB's (and WWV and WWVH) demise have been floating around since a congressional budget proposal to shutter both the Hawaii and Ft. Collins operations leaked out. WWVB is the one that the new Pulse Modulated clocks use.
navychop
Member of the Month - July 2014!
60,016
27,290
Northern VA
I’d be err, “perturbed” if several of my clocks suddenly did not keep proper time.
Are newer ones using GPS as the time reference?
Sent from my iPhone using SatelliteGuys App. For now.
harshness
18,890
4,065
Salem, OR
I can't think of any consumer models that do. GPS-based units typically (if not exclusively) require an outdoor antenna and that's not a practical requirement for a wall clock or wristwatch. Perhaps not obviously, GPS wristwatches typically can't receive GPS signals indoors.
