Zinwell WB68 switch interference?
cebu22
51
Hi,
I recently installed a direct tv international dish and aZinwell WB68 switch to my capture 95 W satellite channels. My setup is as follows:
DirectV AU9 Slimline Ku/Ka Dish connected to inputs of WB68
Directv International Dish (95W) connected to WB68 Flex port
Shortly after installation I started to noticed clear diagonal lines traversing the
screen on my projection television. Could this problem be related to the WB68 switch? Any suggestion would be appreciated.
Are the lines still there if you disconnect the line to the flex port?
Which flex port did you use?
Is this visible on both tuners and all receivers?
Thanks for responding.
I don't recall seeing the lines on my other 2 television sets. I may be mistaken but the lines appear to be isolated to my HD projection television only. I will re-examine my other television sets tonight.
My international dish is connected to Flex port 1 on the WB68 switch. And, I haven't tried disconnecting the international dish from this port.
Once again thanks for your interest.
