PBS and Claro on AMC21 125W
Martyn
636
278
Annandale, VA
I'm thinking of shifting the dish a little today to see if I can clear some trees and get the PBS mux on 125W. I might lose 83W and 85W in the process, but I rarely have the dish swung over to those.
Anyway, I noticed that I can receive a very strong signal from the Claro mux on 11980V. It's coming in with 70% quality, although Lyngsat says it's on a Caribbean beam and the footprint map shows that hardly reaches Texas, let alone Northern California. Meanwhile, the only PBS I can receive is a broken up signal on the SD07 transponder, peaking around 40% quality, which should have much better coverage where I am.
Lyngsat shows Claro using several transponders. Is perhaps 11980V on a North American beam and the rest on a Caribbean beam? If they are there I cannot detect them.
I'd be interested to know if PBS HD comes in for most people at around the same strength as Claro.
The 11980 TP I could get here in MN. Its as strong as the PBS stations. 11980 use to show 74 quality on the MicroHD
(now remember I havent worked with FTA in over a month so the following info may have changed)
Your strongest PBS transponder is 12180 V 30000 (its DVB-S2)
Montana PBS & Oklahoma PBS are tricky depending on dish size.
The SD07 transponder if I remember was DVB (12175 H 4444) whereas most of the rest are DVB-S2
Try and peak on 12180 then go from there
Thanks Iceberg. I guess Lyngsat is wrong on that Caribbean beam.
I'll use 12180 as I fiddle with the dish. It just needs to come over a little, but hopefully not too much otherwise the house will block out 89W and then I'll lose LPB.
Martyn :
I'm in Northern Mexico and I get all PBS channels (SD and HD) with a 60-70 Quality Signal (except PBS Montana and OKPBS, as Iceberg said). SD07 certainly seems to have the strongest singal in that Satellite (KU), but it shows color bars almost all day.
I have been out of the country for 3 months and now all I get on AMC 21 for PBS is 1 channel of test pattern.
Did they switch to some newer format or change transponders since Oct?
What do I need to do to get PBS on AMC 21 again
I am on a VS MAX HD
Welcome to the site wyomingfly.
Most of the stuff on AMC21 went to DVBS-2 last fall. Not familiar with that receiver.
you'll need to upgrade the receiver
That receiver has a DVB-S2 card option in it but it was designed for "Turbo" which is what Dish uses (in other words it was mainly used to steal) and wont work with legit fta
Specs in the manual for for input says DVB-S2 10-30ms/s (QPSK) FED decoder DVBS2
Do I really need a new unit? I see VeiwSat is no longer.
What would be a decent cheap unit that I can get PBS on these days?
How does the MicroHD deal with the AC3 audio. Current setup I have to take audio via fiber to a separate audio system that decodes the AC3
The microHD either decodes internally and outputs via HDMI and/or RCA or outputs raw via HDMI for external decoding.
Coolsat 5000 will work?
Hi everyone, I'm at the norwest of Mexico, only have a CS5000 receiver, please let me know if can work with this sat to watch PBS.
Best Regards !
