Combine signals from Dish 1000 and Dish 500
destrada
112
Lockhart, TX
I did a search but couldn't find anything. I have a Dish 1000. My Austin HD locals are now available via 61.5. Can I combine the signals from my Dish 1000 with the signal from a Dish 500 pointed at 61.5 with a SW21 switch?
What type of receivers? Dual or single tuners? Number of receivers is important too.
I have a 625 and a 622. Not really worried about the 625 because SD locals were availble to me before I "moved" to San Antonio.
Since you have dual tuners receivers your best bet is to go with a 1000.2 dish. You run a cable from the 61.5 to the 1000.2 dish and run check switch on both receivers. Your other option is a DPP44 switch. The 1000.2 dish allows you to have 4 satellite locations and feed up to 3 dual tuners.
You CANNOT use legacy switches with DP lnbs or switches. So your SW44 and SW21 are out.
A dish 1000.2 can do what you want or also a DPP44. A DP34 can as well but each receiver would need 2 lines to it.
what is "DISH NETWORK DVR SERVICEFEE" on my bill?
Dish Network install question
