Complete signal loss on transponder 10 ?
robert6715
32
7
Afognak island
I have 4 receivers in 4 different rooms, 3 are 211k's & 1 is a 211z, all run thru a DPP44 switch. The 211z has "complete signal loss" on every channel that uses transponder 10. I have swapped receivers around from room to room and the problem seems to follow the receiver.
Am I safe to assume that receiver needs replaced, or does anyone know of a fix?
Thanks in advance
Rob
That was a good way to isolate the problem. Try to do a check switch without the dish connected to that receiver, then hook it back up and do another check switch. Also if that one receiver is not seeing all the satellites after doing the check switches that the others are seeing the receiver does probably need to be replaced.
Thanks in advance
Rob
More than likely you have a bad receiver.
TP10???
61.5, 72.5, 77, 110, 118.7, 119, 129 ???
Samsung Galaxy S6 Active
BBC World Service - Dish Anywhere
Hopper 3 guide error
