Dish 500 Legacy Twin-Dish 322 Rec.
Davevh@comcast.net
18
Las Cruces NM
Ladies and Gents
I am attempting to use a Dish 500 Legacy twin on a NIB Dish 322 Dual Rec.
I have RG6 cables running straight from 119 side to the Sat1 input and from 110 side to Sat2 input. I have, so far, only been able to get one tuner to "see" the two birds.
I am under the impression that a D" 500 Legacy Twin can be used with a 322. Am I wrong?
If anyone has good constructive criticism it would be accepted with open arms.
I would try the Check Switch once or twice more, but since you appear to be receiving both 119 and 110 on one tuner, maybe you need a software download, or you are in SINGLE MODE instead of DUAL MODE.
Also, swap Sat-1 In and Sat-2 In and see if the tuner that is receiving the signals changes. If it does, than one of the cables is bad, or is not making contact.
Dish Network HD Receiver Upgrade
Legality of Dish Network in Canada or Mexico
