DPP and Antenna Diplexer?
GaryPen
Rich or poor, it's good to have money.
Can I use a diplexer to combine DPP and Antenna signals from the dish to the receiver? Will it work if I am also using a DPP Separator?
I would like to use one cable to feed both sat tuners and the antenna input on a 612/622/722.
Thanks.
Thank you kind sir. I thought I once read, way back in the early DPP days that diplexers were a non-no with the "new" Dish system.
The only requirement is if you use a DPP44 switch. You will need a blue holland diplexer rated 2Amps for the power supply on port 1. You can still use regular diplexers on port 2, 3, and 4. If you use a DPP Lnb then this doesn't apply.
Thanks! I'll just use the Holland diplexers, regardless. That's what DishStore sells, anyway.
Considering the switch to DishNetwork
Need help with a multiswitch task
