H21 / H23 CE Release v.4339 7/17 & 7/18
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
Friday, 7/17/2009, 11pm - 2:30am ET
Saturday, 7/18/2009, 11pm - 2:30am ET
H21-100, H21-100, H23-600 (x4339)
Areas of Improvements & Updates
* Hide HD channels
* Stability
Notes
· H21-100: High Risk
· H21-200: High Risk
· H23-600: High Risk
· Going back to National will go back to default settings and lose local market ID setting and may lose service authorization.
· To enable Multi-Room View Client, perform "IAMANEDGECUTTER" keyword search. Bring up the Miscellaneous Options screen by pressing Menu->Setup->Miscellaneous Options. From the Miscellaneous Options screen, select Multi-room DVR and choose ON. Also setup Networking on the HR2X and H21. H21 MRV feature will work properly with HR2X CE version x339 only.
· Please report all issues, including MRV.
Previous Release Notes:
New Features
01 - Network
01 - Media Share
01 - Music Screen Saver
01 - Game Search
01 - 1080p/24
01 - OTA via the AM21
01 - Autotune
01 - Multi-Room Viewing
:::::::View Playlist from a networked HR2x or R22
:::::::Playback/Trick Play functions from any networked HR2x or R22
:::::::Press {LIST} to see HR2x or R22 servers one playback per server at a time
02 - Parental Controls when scheduling autotune
02 - MRV: bookmarks and resume playback from previous location
04 - Friendly name in network setup
04 - QuickTune
05 - Built-in Self Test
13 - Advance setup in remote control
Improved/Updated
02 - Support for more 1080p Sony TV models
02 - Faster Guide scrolling
02 - ATSC signal meter performance
02 - Fixed a screen saver issue
02 - ATSC setup screen now works on first boot
02 - Fixed reappearance of deleted autotunes
02 - UI updates ("tuner 2" and "tuner 3" references)
02 - Fixed Gray Screen or a PPV OSD appearing overnight
02 - Improved "Try Again" when trying to connect to the Internet.
03 - AV1/AV2 remote code refinements
03 - Improvements to DHCP network setup
04 - Issues with rebooting while in standby
04 - WGA600N Support
04 - Static IP Setup
05 - Stability
05 - Missing "Just a few seconds" OSD
05 - MRV playback and trickplay problems
05 - User Interface polishing
06 - Network services, Network setup, Network status
06 - One touch autotune via Enter key
06 - H21-100, SWM compatibility--will not affect other boxes
06 - H21-100, remote control support
06 - Removed "Reformatting Hard Drive" screen after Reset Everything
06 - Changing Display Language
07 - One touch autotune via Enter key
07 - WGA600N setup with WPA encryption
07 - Receiver not resetting
07 - Closed Captioning Loss
08 - Autotune on ATSC channels
08 - WGA600N setup with WPA encryption
08 - UI Improvements
08 - Missing spending limit unlock OSD
08 - SWM issue, Signal Strength H21-100
08 - System test H21-100
09 - Network Setup
09 - Autotune on ATSC channels
09 - Keyword search
09 - Screen flash coming out of Standby
10 - Improved Front Panel display on boot up
10 - IR Remote H21-100
10 - Remote setting when reset defaults
11 - PPV spending limit conversion (compared to national release)
11 - Video when switching to alternate audio
11 - Fixed blank reset everything screen
12 - Stability fixes
12 - Faster keyword search
12 - Reset everything warning message
13 - Autotuning when using parental controls
13 - Fixed "tune to 201" issue
13 - Reset defaults correctly sets the hide/show SD duplicates option
13 - Updated connection successful message in Network setup
13 - Stability
14 - Autotune Fixes:
::::::Manual with past start times
::::::Lingering icon after canceling
::::::Parental Controls
::::::Minor polishing
14 - Updated welcome screen and help messages
15 - Autotune Scheduling with Viewing Hours set
15 - Preserve favorites when converting from NDS to DIRECTV firmware
15 - HDCP content protection H23-600
15 - Minor polishing
16 - Additional improvements to items from previous CE
17 - Scheduling autotunes
17 - Resetting the set-top-box in standby
17 - Call ID inconsistency
18 - Scheduling autotunes
18 - Coming out of standby
19 - Showings in Info Screen
19 - PPV autotunes when converting to new Middleware
20 - Improved tuning stability
21 - Under the hood
22 - MRV
22 - Aspect ratio changing on certain channels
22 - Bookmarks updates
22 - DIRECTV Subtitling (in TV options)
22 - Stability
23 - Autotune to XM Channels
23 - Stability
24 - Parental control
24 - Autotunes
24 - Stability
I cant believe? it's finally here. Hide hd channels. It's a Directv milestone, a day in history to mark down on the calender. The day I thought would never come. Now that we use HD DVR's for are standard dvr's, so no more gray bars on the locals. And soon we wont have to teach the customer to channel one up. I'm so friggin exicited about how much better this is going to make my job and by not downgrading the cutomer with dumd stuff when we tell them it's an upgrade.
Still the same problem as the last CE release: The MRV list on the H21-200 is not in sync with what is on my HR22-100 DVR. A reboot of the H21-200 will sync it, but new recordings on the HR22 will not show up and the H21 will continue to be out of sync until a reboot.
To sync up the lists, you may want to try pressing the yellow button while looking at the list and chosing to sort a different way the change it back to the way you like to view it. This seems to be a very effective way to update the list.
That worked. But, it's kind of annoying that I have to do that. Hopefully, this will be resolved soon.
Problem Report: 2009720-2948
H21-200
H21-200
Diagnostic Report 20090729-3F78
Using MRV and receiver won't recognize any shows from my HR20-100 playlist. They won't show up at all. Picks up shows from my R22-100 just fine.
CE software
How do I get the latest CE software? I s there a certain time and say of the week to download it? My HR21 and 23 both are currently running 0312.
MRV over SWM
Hangs during playback - related to AM21?
