Help Finding 129
JIGGIEFLY
390
Melvindale Mich.
I have a dish 500 i would like to put at 129 for the voom channels it is at 61.5 now and i would like to set it next to my superdish that is at 110/119/121 so all my dishs can be in one spot. were is the best site to find azmith and elevation & skew so i can get it set up for my area.
Just for reference, 129 will be about 5 degrees lower and 10 degrees west (to the right, if standing behind a dish 500) then it would be for 119. If you are using a dish 500, use the 119 side of the Y adaptor, set the skew to 90, and start with the peak angles for the 119 sat on a dish 500, then move the elevation down about 5 degrees, and then slowly turn the dish to the right until u get signal. You may have to adjust the elevation a bit from there, but you should be able to see some signal on the point dish screen.
Loss of color on rewind?
942 connection question
