New install need 3rd receiver
dummy85
Texas
I currently have one dish with 2 ports out and one port in. 2 receivers running 4 rooms. the installer used diplexers on the outside with separators on the backs of both receivers. i also have a dish 311 that i want to hook up. the room is already wired but i cant figure out where i would "splice" into the current lines on the outside. What can I do?
Probably his work order called for that type of install and he didn't want to modify it.
You will need 2 new lnbs DP singles. they will go right on to the same bracket.
and a DPP 33 switch.
If I were you, I would call Dish and generate a Trouble Call for an incomplete install.
Any way to remotely wake up a 722 (maybe with a timer?)
In need of (23) VIP 211k receivers
