Orb & 622
phillycreamboy
40
Hi everyone-
I have a PC with a tv tuner card and ORB installed. I want to be able to hook up my 622 to the pc but TV2 doesn't use IR and I have TV1 hooked up via component cables to my lcd tv. Am I out of luck?
so far yes if you want to use TV2.
All the TV1 outputs are active at the same time so you could use TV1 with appropriate cables.
I have heard that TV2 IR support is "coming"
well the input to the pc card can support s-video or video/audio yellow/red/white. I have the audio left and right (red and white) going to the input on my tv. Would I have to buy a splittler to split the audio, then use the audio out from the 622 to both the tv and the pc if I am using TV1?
There are two sets of composites (yellow, white and red) and when using single user mode, both sets are for tv1 so no splitters would be needed. If in dual mode, they are separate and if tv2 used for another tv, then you would have to split the audio from tv1, the s-video and yellow composite would both be active and could be used. Note that the s-video is for tv1 only.
archos av700 vs av700e?
Uplink Activity Report - 12/06/2006 - 20 changes
