Split Joey signal to second Tv
ashutto20
1,255
85
United States
Wanting to know the easiest way to split a Joey signal to a tv in the backroom... The wires are near each other and I have a 2 way splitter... Please help
Thank you
Thank you
You can use the other output. For example if your already using hdmi output you can run composite (rca) output to your backroom or split the hdmi output using a hdmi splitter and from splitter run hdmi cable to each television.
Sent from my Z958 using Tapatalk
You should be able to split the composite out using (3) rca splitter plugs, one of the red white and yellow output plugs.
2 TVs 2 Receivers to existing dish setup.
Cannot set timer
