Warning: Dish PVR DVR 522 won't work without the EEPG (9 day guide)
Witschey
35
The purpose of this new thread is to raise awareness among of you who may be considering adding a 522 receiver to your Dish Network accounts of a serious design fault (I would call it a bug, but Dish says it was a design choice), on the 522 receiver.
In a nutshell the bug (or design choice as Dish likes to call it) is that the 522 receiver will NOT work well unless your receiver is able to download the 9 day program guide (EEPG).
Without the EEPG (9 day program guide) your receiver WILL NOT be able to use Name Based Recording or Recurring Events properly. No recording events will be created on a recurring automatic basis when a new program guide is downloaded to the receiver.
A more detailed explanation of how this affects the receiver is contained in the complaint letter that I wrote to Echostar (a copy of which is shown below).
I would like to encourage all of you who are affected by this issue to contact Dish Network and complain about the situation.
Please write a complaint explaining them clearly that you are facing this same problem (you can cut and paste parts of this message if you want) to the following email addresses
ceo at echostar period com
dishquality at echostar period com
NOTE: The system won't allow me to write the addresses posted above in standard format, since I am new on this bulletin board. Please put the address in standard format before sending your complaint to echostar.
Since the problem with the 522 receivers is due to the fact that they require the EEPG (9 day guide), and the reason a lot of us are unable to get the EEPG (9 day guide) is becausse it is located on a weak transponder (29) of a weak satellite (satellite 110). I have written a complaint letter to Echostar in which I outline what they should do to solve the issue. Feel free to cut/paste areas of this e-mail when you write your own complaint letter to Echostar. Please note that in order for Echostar to do something about this issue they need to receive more complaints on this issue, or otherwise they consider the issue 'statistically insignificant'.
Letter I wrote to Echostar:
I would like to file a complaint regarding the choice of Echostar to only put the 9 day program guide (EEPG) on transponder 29 of the 110 degree satellite.
The choice to put the EEPG only on transponder 29 of the 110 degree satellite AND at the same time designing receivers (like the 522 which I own) that will ONLY work properly when they have the EEPG (9 day guide) is making our equipment useless.
I believe Echostar should do AT LEAST ONE of the following things to help those of us who are having problems.
1) Echostar should put the 9 day EEPG ALSO on the 119 degree satellite. Echostar has installed SO MANY DVR/PVR units that numberwise there is already enough justification to put the guide also on satellite 119. You have the 44 guide on EVERY single satellite. Why not have the EEPG at least on two satellites (the 110 and the 119)?
2) Echostar should move the EEPG (9 day guide) to another transponder on satelite 110 which has more power, an is therefore MUCH more likely to be received by ALL Echostar Subscribers regardless of whether they live in the continental USA, Alaska, Hawaii, the Caribean, etc...or even people like me who have trees/buildings in the way who can receive transponders 1 to 21, but NOT transponder 29!!!! (most of the transponders from 1 to 21 are OK).
3) Echostar should update the internal software of the DVR/PVR receivers so that the receivers will fetch the 44 hour guide whenever they are unable to fetch the EEPG (9 day guide). At the present time if a DVR/PVR is connected to both satellite 110 and 119 and it is unable to fetch the EEPG program guide (for example because transponder 29 can't be received..eventhough transponders 1 to 21 CAN be received) from satellite 110 it simply wont fetch ANY guide at all. A simple 'Conditional' in the programing of the receiver would solve the problem. Something like: If EEPG can't be retrieved during the first three attempts retrieve the 44 hour program guide.
4) Echostar should update the internal software of its newest PVR/DVR receivers (like the PVR 522) so that they are able to work properly with the 44 hour program guide. A person who has the receiver connected to both satellite 110 and 119 but is unable to access the EEPG because of the weak signal of transponder 29 will NOT get ANY program guide at all as documented in point 3 above. A receiver that is connected to one or more satellites (like the 119), but NOT to the 110 satellite WILL be able to download the 44 hour program guide successfully. However, the PVR 522 receivers only work well when they have access to the EEPG (which currently is only available through a weak transponder (transponder 29) on the 110 satellite. If a person (like me) can't receive a good signal from transponder 29 (because it is too weak to pass through trees, neighbour walls, etc) the PVR 522 recurring events and name based recording WILL NOT WORK properly. The reason for this is that Echostar currently has a software on the PVR 522 receiver that REQUIRES the 9 Day EEPG program guide for the NBR (name based recording) and recurring recordings to work properly. Withou the EEPG the recurring events/nbs will ONLY work initially (when the recurring event is first setup), but will NOT setup new recording events as new programming days are downloaded by the receiver. So in essense, a person who can't receive the EEPG will be able to ONLY setup recurring events that span 44 hours; and then that person will have to reprogram the receiver's recurring events to be able to record those shows again. The receiver WILL NOT setup new recording events as days go by...unless it has the EEPG (which is ONLY available on transponder 29 of satellite 110).
Please note that Echostar DOES NOT mention ANYWHERE on the manual that people who buy a 522 receiver need to have access to satellite 110; NOR do they mention that a VERY good signal to satellite 110 is needed (where transponder 29 gets a very strong signal). In fact the manual of the 522 shows MANY different ways of installing the 522 receiver, which include connecting it to other type of dishes that are NOT the 500 series dish. So in short, Echostar has failed to state the requirements for the good funtioning of this (and perhaps other) receiver(s).
A few days ago I spoke to 'Steven Murphy' (Technical Product Support Department). He told me that he didn't view the problems that some of us are facing with the 522 as a problem, because we were not 'statistically insignificant'. When I asked him what he meant by 'statistically insignificant he told me that we were a small group of customers who were facing this problems, and Echostar wasn't going to chance things for us.
I find 'Steven Murphy' (Technical Product Support Department), statement VERY rude and unprofessional.
First of all I don't know how Mr. 'Steven Murphy' (Technical Product Support Department), arrives at the conclusion that we are not 'statistically significant'. The amount of discussion on this topic on satellite bullentin boards on the internet is quite large; and people who take the time to document their problems on a satellite bulletin board on the internet are a small minotiry of the people affected by the issue. So the number of affected people is larger than that shown on discussion boards on the internet.
Second, even if the number of dish network customers affected were relatively small, compared to the total population of dish customers, I still don't believe that a customer oriented company like Dish Network would simply ignore the problem that were are facing and completely refuse to tackle the problem, simply because we are 'statistically insignificant'.
Third. Dish Networks DID NOT state in the manual OR on its website that having access to the 9 day EEPG was a requirement for the 522 receiver to work. They did not say that the 522 receiver required access to the 110 satellite for it to work, and they also DID NOT state that a 500 antenna was needed. Therefore, Dish Networks has a certain obligation to fix this problem since they did not state it as a requirement. I for once BOUGHT my 522 receiver (I didn't lease it); so I expect the problem to be fixed; otherwise I won't be able to benefit from my purchase and it will have been money wasted!
Fourth. In addition to those of us in the continental USA who are unable to receive transponder 29 of satellite 110 (and therefore can't receive the EEPG), there is all those people in Puerto Rico, Alaska, Hawaii, Caribean...who are ALSO unable to receive transponder 29 of satellite 110, even if they buy a large dish that allows them to get transponder 1 to 21 of satellite 110. I find it completely ridiculous that Echostar would put the EEPG on a satellite that is difficult to reach in some parts of the USA, when they have a satellite (119) that can be easily received everywhere. Even if satellite 119 was full and there was no more space for the EEPG on that satellite, Echostar could put the EEPG on a more powerful transponder on satellite 110 so that people could easily get the 9 day guide. However, instead of this, Echostar has chosen a weaker satellite and as weaker transponder to put a guide that is no longer an 'option' to have it, but a hard SOLID requirement of the new receivers (like the PVR 522) for them to work properly. Without he guide the receivers do not work properly; so Echostar has a customer service obligation to put the guide in a place that can be easily accessed by EVERYBODY no matter where in the USA we live; OR change the programming of the receivers so that the 9 day program guide is not a requirement but rather a 'nice to have' thing.
Dear Sir
I have never heard of this problem and I have been installing Dish, Direc, Direcway and Starband for over 6 years and have installed thousands of dishes. I would have to say you need to look at the alignment of your dish as for 110 trans 29 is one of the highest signal strengths on a couple dishes I have checked since I read this. My Dish 500 thru my 522 reads 111 signal strength and on my 510 reads 124. Its also funny how you mention the Caribbean repeatedly in your article where if you had Dish Network you would be getting your signal illegally.
rowemance said:
Dear Sir
I am NOT based in the Caribbean, but I do know people living in the US Virgin Islands....as well as people living in Hawaii (I scuba dive as a pass time), where they are facing the same problem that I am having. My friends in the US Virgin Islands and Hawaii are both paying customers of Dish Network. I have had e-mail contact (though other bulletin boards) with people in Puerto Rico and Alaske who also face the same problem...eventhough the have installed a larger dish to get satellite 110. They can get transporters 1 to 21, but not 29...which is the one with the guide.
Please DO NOT try to imply that I am receiving the signal illegally. I have been a full paying customer of Dish Network since more than a year. I first had a 508 receiver and that one worked fine (it doesn't need the EEPG to work...can work fine with the 44 hour program guide). I am based in Atlanta, Georgia!
Yep, plenty of legitimate DISH customers in the US Virgin Islands and Puerto Rico. I know an authorized dealer on St. Thomas . . .
I Never suggested you were not paying for your service. All I meant was that Dish service is not authorize in many parts of the Caribbean and was mainly set up for the Lower 48 states. But if you live in Atlanta, GA you must have another issue with your system that is causing you signal problem. I think you should have a professional installer come out and check your dish.
Jordan420 said:
Why start 2 threads on this?
Sorry for starting two threads on similar topics. I didn't think a lot of people who read one thread would be reading the other. I used different titles to the treads to capture the attention of people looking at different things...but now I see that a lot of people (like you) are reading both.
I have taken my 522 to the house of a relative living in Florida and the receive is able to get the EEPG there. So my 522 seems to be OK. Some of my other neighbours living in the same building have the same problems with satellite 110. I only learned this after beign faced with the problem and starting conversation while picking up mail, in the stairs, etc.
But putting my situation aside. Why is Dish Network making a receiver that only works with the EEPG and not with the 44 hour program guide (when the 508 receiver worked just fine with the 44 hour program guide). Why aren't they documenting the fact that it is as requirement to have access to satellite 110? Why don't they copy or move the EEPG to satellite 119 where EVERYBODY in the subscriber area can access it....or why don't they update the software so that the receiver can work with the 44 hour program guide...just like previous models did. Previous models worked with BOTH the EEPG and 44 hour guides.
You need to have your dish repeaked or perhaps your lnb replaced. There's not a reason you can't get 110 t29 well enough for your 522 to work without some sort of problem existing.
What is your signal level on 110 t11 and t12?
I have a signal of 83/85 on t11 and t12 on 110. Similar thing for all other transponders in the range 1 to 21. Nothing on transponders 22 to 29. Same thing experienced by neighbours who face same direction as I do in buidling.
I appreciate your help on this, but while I am a new member of this forum I am not new to satellite TV. I have already tried replacing LNB and realigning antenna (within the bounds of what I am allowed to do in this building). I even replaced the coax cable.
But rather than delving into my particular case; why don't we discuss the larger issue at hand; which are:
1) Why did Dish Network launch a receiver that only works with the EEPG...when previous models (508 for instance) worked with BOTH the 44 and EEPG?
2) Why did not document that access to the EEPG guide was a requirement for the proper working of hte receiver
3) Why do they have the EEPG guide ONLY on one satellite (110-tp29) whereas the 44 guide is on EVERY satellite.
4) Why did they choose a satellite and transponder that can't be accessed by people living in many service areas (particularly ourside of hte contigious states)...such as Hawaii, Puerto Rico, Virgin Islands, Alaska?
5) Given all of the above,why aren't they doing anything about it?
closed...see this topic
http://www.satelliteguys.us/showthread.php?t=65269
4/14/05 Live Retailer Chat Recap!
522 Name Based Recording Problems
