What Do I Need To Add 118.7
No_Brains
226
Princeton, WV
i currently have dish network with dish hd and have 110 119 and 129. i want to receive some international services and need the 118.7 my ? is what do i need to add 118.7 to my set up
i have the current setup dish 1000
my switches from the system screen says that i have a
dpp 1k.2 w/ seperator
so what else will i need
any help is appreciated
Sounds like you will need a 1000+ dish. This will enable you receive signal from 119, 110, 129, and the 118.7. However, you will also need a DPP 44 switch to combine these signals to your receiver(s).
The superdish will work but not the 105 LNB, you need to use an LNB from a 500+ or 1000+.
It has a 118/119 LNB assy that will fit on the 105 SD
There might be a repoint kit for the 105 dish that will convert it to a 1000+. I know they have them for the 121, not so sure about 105. If a DPP44 switch can't be obtained for a good price, you can run the cable from the 118.7 LNB over to the LNB IN port on your current 1000.2
I don't mean to be redundant
622/722 External HDDs now movable between boxes ?
