Why are cell towers so thick when other broadcast towers are so skinny?
The picture above is a typical cell tower. It's very wide at the base. Sometimes they are a bit narrower but still very thick, similar to this one:
That's still pretty thick compared to some broadcast towers which are extremely thin. Here's a typical example of a broadcast tower:
That tower is so thin it needs to be held up by guy wires. Sometimes you'll see cellular equipment on a tower like that, but it's rare. Most often cell towers are fairly thick affairs.
So why?
It's actually a pretty simple answer. Cell towers have more stuff on them. A typical cell tower will have transmitting and receiving equipment for more than one carrier, and in order to make the most of their investment, a tower owner will put multiple antennas up there. That gives the most capacity and let's be honest everyone wants more cell capacity.
The weight of all that equipment means that cell towers have to be sturdier. A typical radio or TV tower is going to have one broadcast antenna on it, that's it. The only reason the tower is there is to get that broadcast antenna up high.
It really comes down to an understanding of the different technologies. TV and radio is a one-way medium. You're looking at pushing all the information from the tower into receivers that are located a long distance away. Cellular communication is two-way. You have cell towers which a pushing a strong signal out to a relatively small area, and you have all these devices which are then trying to send a fairly weak signal back to the tower. That means cell towers do need to be closer to the ground, because if they're too high the signal will get weaker unnecessarily. Cell towers also need receiving antennas which makes all the equipment larger.
And it's a little bit of an optical illusion
Those broadcast towers aren't really that much thinner, but they are taller. A TV station is going to want to put the transmitter really high up in the air to cover a larger area, but cell towers tend to be only about 50-100 feet up in order to serve a smaller area nearer to them. Some broadcast towers can be 1,500 or more feet in the air.
Sometimes you will see cellular equipment on the side of a broadcast tower, too; that's just the tower owner trying to make a little bit more money. Often times these are smaller cells that service a very local area. It can be closer to the ground. It still seems large, but this type of equipment is a lot smaller than the large cells on tall towers.
For all your cellular needs, take a look at the great selection of products you'll find at Solid Signal. Or, if you want personalized service, call the experts! We're here for you at 888-233-7563 during East Coast business hours. If it's after hours, fill out the form below and a cellular expert will get back to you on your schedule.
The post Why are cell towers so thick when other broadcast towers are so skinny? appeared first on The Solid Signal Blog.
Continue reading...
Does the KING WiFiMax require a subscription?
Ultimate 360 Laser Level – 43% OFF
