XDIPO software
ZetaMale
17,780
13,666
USA
Has anyone tried this? It's distributed as source code and runs on Linux OS only. I haven't been able to build the program. I thought that the error messages was indicating that I need libgtk*-dev but it still won't build. All kernel source and header files have been installed.
xdipo-0.8.5/xdipo.c:739: undefined reference to `fl_set_object_boxtype'
http://panteltje.com/panteltje/satellite/
The last date I saw there (just went to take quick look) was back in 2012. Might you have some library that is newer than was used and this is causing the error?
Just a thought.
Did you install the xforms GUI library?
Note: This software makes use of the open source xforms GUI library,
xforms can be found at:
http://savannah.nongnu.org/projects/xforms
Without xforms installed it will not run.
Looks like I have xforms 1.0.93 installed. I see a tarball for 1.2.x but no Ubuntu packages for 1.2. I guess I'll install the 1.2 tarball and see what happens. Not sure if I really need the xdipo package but I plan to find out if it's useful.
How to determine the elevation angle of Offset dish
58w Intelsat 21
