I think you're fine, looking at your photo, the Arm Clamp should be just a few inches from the end, away from the motor.
oh ok. I will move that tommorrow.I think you're fine, looking at your photo, the Arm Clamp should be just a few inches from the end, away from the motor.
Oops I knew I had 2 open I forgot about the one and 1 I put in a Sadoun thread but no response from them. I bought it from them.merged the three threads together...lets try and keep all the install issues in one thread![]()
Thanks.The markings are for a fixed Dish.
For a motorized, start with Zero to Polar Axis, you may have to Tweak just a little.
eew broken ring that holds lnb in place. Must be thinner than my other one.However I found my first satellite signal. Muahahahahahaha
Oprah Winfrey Show wild feed. I have no idea what satellite I am on yet. But I have one the others should be easy to find.
ok thanks.You might be on G26 (formerly T6) @ 97W? Orbit is showing Oprah appearing on tp 24 M-F @ 4:00 EDT. anyways...Congrats on getting a picture!!!![]()
Hmm. I can only find 2 satellites. Galaxy 16 and AMC 1. Something outta wack I guess. Just found NASA Its set for Galaxy 14 so I guess I found that one. lol
I think I am lost now.If you are seeing NASA on C-Band you must be on AMC-7 @ 137W or AMC-6 @ 72W?
I need something fresh. I have a signal but I think I was just lucky.Just throwing these your way, as a "fresh" perspective...
Did you go the correct way for the Deinclination? At your True South Sat the Dish should be at 32.5 (elevation - deinclination)
What are you using for your True South Sat?
