Which one?
dougy
59
Sioux Falls, SD
I'm thinking of getting a Monster Power Powercenter for my home theater system but not sure which one. What do you all think of these two? Thanks in advance!
[ame=http://www.amazon.com/Monster-MPHPD1800-High-Definition-PowerCenter/dp/B001CBPWT0/ref=wl_it_dp?ie=UTF8&coliid=IIU384AQXB9DK&colid=23F6HXGNI4L0]Amazon.com: Monster Cable MPHPD1800 High Definition PowerCenter for Audio Video: Electronics[/ame]
[ame=http://www.amazon.com/Monster-2500-High-Definition-PowerCenter/dp/B001D8J9JQ/ref=wl_it_dp?ie=UTF8&coliid=IXU8GUSBQM7QV&colid=23F6HXGNI4L0]Amazon.com: Monster HDP 2500 High Definition PowerCenter - Surge suppressor ( external ) - AC 120 V - 11 output connector(s): Electronics[/ame]
navychop
60,019
27,296
Northern VA
DO NOT GET EITHER! Please. ;)
Monster makes good stuff, but they are way overpriced. Go look at APC for something like these.
navychop
60,019
27,296
Northern VA
Also good products. Have to check to see if Panamax has one meant for AV use, vice PC use. Yes, there's a difference.
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,312
1,107
Elk Grove, CA
Panamax and Furman are some of the best. Panamax has a complete, topnotch AV component line for HT. They also have a floor model line for PC or HT depending on your needs. I use the 7500 Pro a lot with whole house distribution setups.
S~
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
31,320
19,225
NE OH
Monster is the only company I have heard of...
Monster makes good products. However, they are very overpriced.
A huge portion of their price goes toward the advertisement: to make sure that they are the only company you have heard of. ;)
Shop around!
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,312
1,107
Elk Grove, CA
The 5300 EX can be had for 249 on Amazon right now. Great deal. The PM is $499.
[ame=http://www.amazon.com/Panamax-M5300-EX-Outlet-Power-Conditioner/dp/B000ATEVVK/ref=sr_1_1?ie=UTF8&s=electronics&qid=1235335315&sr=8-1]Amazon.com: Panamax M5300-EX 11 Outlet Power Conditioner: Electronics[/ame]
ingram4868
Feb 22, 2009
3
NV
I've been very happy with the Panamax M5400-EX. I have the entire home entertainment system, powered speakers and plasma TV connected to it.
jayn_j
Press On Regardless
10,997
4,012
Sheboygan, WI
In this case, I wouldn't say that Monster makes good stuff. This is nothing more than a fancy surge protector.
You can actually divide these devices into two classes. The first class basically uses passive devices to do some basic signal conditioning. This conditioning consists of Metal Oxide Varisters and Transorbs to attempt to catch and absorb a power spike. Some higher price devices will also add low pass filters to block higher frequency line transients and a simple low pas filter to block DC offset voltages. However, they won't handle line frequency fluctuations or voltage changes, especially sagging voltage drops.
This is the sort of device the Monster conditioners fall into.
The better conditioners will take a line input, pass it through a transformer and full wave bridge diode network to create a regulated DC signal. This signal is then used to generate a pure 60 Hz AC signal that is then amplified into a regulated 120V output. This second design is far superior in that there are two stages of isolation between the input and the output. The output signal is also frequency and voltage regulated.
This second class of device actually provides a good level of protection against lightning strike as well.
The real question is whether all this is needed. Modern powr supplies tend to be efficient switching supplies that will generally handle voltage variations and very little, if anything in the modern HT electronics relies on line frequency. The only real issue is surges and lightning strikes.
Lightning strikes are something that you really can't effectively protect against, and they are generally covered by your basic homeowners or renter insurance. They are as rare as.... getting hit by lightning. I'd personally use a lightning strike as an excuse to let the insurance update your equipment.
Kevinw
Just a regular guy
3,002
14
Jacksonville, FL
I have Belkin PureAV Home Theater Line Conditioner - AP21101-12 - Buy.com
It is discontinued but this is the replacement [ame="http://www.amazon.com/Belkin-Home-Theater-Power-Console/dp/B001545OYC/ref=sr_1_1?ie=UTF8&s=electronics&qid=1235391842&sr=1-1"]Amazon.com: Belkin PureAV Home Theater Power Console PF31 - Surge suppressor ( external ) - 11 output connector(s): Electronics[/ame]
I would suggest one with a battery backup or UPS.
Both the Monster ones you mention are under specced in comparison to the brands suggested for you and the suggested brands can be had much cheaper.
HD MM
15,837
2
Believeland, Ohio
Here's what I use.....
$20 at Staples. Protects all my equipment just fine.
MisterLas
263
Flemington, WV
I have two of those in play.... and two of these: [ame=http://www.amazon.com/Belkin-Components-F9M923-08-9-Outlet-SurgeMaster/dp/B000068CNU]Amazon.com: Belkin Components F9M923-08 9-Outlet Maximum SurgeMaster: Electronics[/ame]
MisterLas
263
Flemington, WV
Hmmmm... interesting way the amazon links are getting formatted... hadn't seen that on this forum yet. Be cooler if they all showed the item of the picture and price of the item.
jayn_j
Press On Regardless
10,997
4,012
Sheboygan, WI
I think it is because Amazon's prices change hourly. You are never absolutely sure of a price until you hit checkout.
mike123abc
Too many cables
25,357
4,604
Norman, OK
I got the monster 2500 at Circuit City for $150. It was reasonably priced at $150, I would not have paid $399. My CC had a ton of monster power strips and conditioners left.
