dish.sling.com - unable to register DVR
usmaak
57
Hey,
I have a vip722 DVR that is connected to the internet. I can go to Menu + 6 + 1 + 9 + 1 and see that it is connected. I can also go into my router and see the connection. Yet when I try to register the DVR, I get the following message:
Your DISH DVR does not apper to be online.
It is online. I can even ping it from within my network. Any ideas what else I can do to get this to work? I also made triple sure that I was using the correct receiver id.
Try using the remote access site through your dish network account. Login to your account via dishnetwork.com and find the link. Maybe it will work there.
I would definitely do that if I could. Unfortunately I got Dish through ATT, and that's not an option for me. I have to use sling.com.
Outside of triple-checking that you got the DVR ID number correct, I'm not sure what to suggest. Note that it may take a little while for DISH to find the DVR after you've set it up for the first time. If you don't see the Ethernet port activity light flashing once in awhile, something is wrong.
As always, verify that the Broadband Connection status is "Connected Online".
:) I can't get it set up. That's the problem I'm having.
I guess it's not all that important. Life is too short for dealing with stupid computers.
Did you triple check the receiver ID you entered on the Sling website with the actual info screen? Print the form out if you can't see the TV from the computer.
It really isn't that hard if you're diligent and using the right number.
phoneline and network connection question
vip 722 OTA problem
